Should I remove the brake rotor bolts?
Old Nov 18, 2003 | 02:39 PM
TypeRuz's Avatar
Default OK to remove brake rotor bolts?
i want to remove the 2 phillips bolts that hold the brake rotors onto the hub and keep them off. they always get in the way and are a bitch to remove.
is there anything wrong with not keeping them on?
i figure that when the wheel bolts up it should hold it nice and snug anyways.
Old Nov 18, 2003 | 02:42 PM
rainman's Avatar
Default Re: OK to remove brake rotor bolts? (TypeRuz)
Ditch the screws if you replace your rotors often. Like you said the wheel keeps it securely on there.
Old Nov 18, 2003 | 02:46 PM
MackSpeed-616's Avatar
Default Re: OK to remove brake rotor bolts? (rainman)
agreed
Old Nov 18, 2003 | 02:47 PM
nEoMuGen's Avatar
Lots of racers don't have the screws on their car. If you insist of having them, keep them barely hand tight so you don't need an impact driver to take them off next time.
Old Nov 18, 2003 | 02:54 PM
Eric R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeRuz &raquo;</TD></TR><TR><TD CLASS="quote">i want to remove the 2 phillips bolts that hold the brake rotors onto the hub and keep them off. they always get in the way and are a bitch to remove.</TD></TR></TABLE>
Looks like you race your car alot... or go through a set of rotors very often.
Old Nov 18, 2003 | 05:12 PM
Backmarker's Avatar
Default Re: OK to remove brake rotor bolts? (Eric's R)
Haven't had em in years. If you insist on keeping them, just use antiseize.
- Phillip
Old Nov 18, 2003 | 05:32 PM
TodaSi's Avatar
Default Re: OK to remove brake rotor bolts? (Backmarker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Backmarker &raquo;</TD></TR><TR><TD CLASS="quote">Haven't had em in years. If you insist on keeping them, just use antiseize.
- Phillip</TD></TR></TABLE>
ditto.
stevescivic
Jul 8, 2007 09:18 AM
crx_in_it
May 26, 2005 03:49 PM
1whitedc2
Jul 16, 2004 10:32 AM
paulzy
Sep 7, 2001 08:07 AM
leechungsr
Aug 25, 2001 03:39 PM
