skunk2 manifold swap - which fuel line replacement
I did a skunk2 manifold swap on my GSR a while ago and havent gotten around replacing the short fuel line (it rubs against the intake tube, which is bad). In case anyone wanted to know, it's the the line that runs from the fuel filter to the fuel rail.
I forgot... which fuel lines from what cars can be used? Also are there any aftermarket fuel lines and do they offer any advantage? tia.
i turned the hose/filter where it connects to the filter a little, gave enough clearance to fit ls cold air intake on my gsr..
