Help resetting ECU of my TPS sensor
Old Nov 18, 2003 | 11:24 AM
h22aLSD
Guest
Posts: n/a
Default Help resetting ECU of my TPS sensor
I just swapped in a h22a w/LSD in my 6th gen accord. it gave me two codes: the knock sensor and the TPS. I wired up the knock sensor correctly and it fixed that problem but it left the TPS sensor. I looked and checked everything and it was connected fine. Still same code. I swapped out the TPS sensor from my original f23 and disconnected the battery. And it still pull the CEL for my TPS and i know my original TPS sensor worked fine, is there any other place i can reset the ecu to get rid of it??
Old Nov 18, 2003 | 11:31 AM
prelittlelude's Avatar
Default Re: Help resetting ECU of my TPS sensor (h22aLSD)
im not sure if the TPS from the f23 with work with the jdm h22a ecu, it may be good but the ecu doesn't reconize the voltages it putting out. tripple check all your wires, and you may have to find another h22 TPS
edit: do you have anyplans for the f23? wanna sell it
Old Nov 18, 2003 | 06:35 PM
h22aLSD
Guest
Posts: n/a
Default Re: Help resetting ECU of my TPS sensor (prelittlelude)
I can sell you everything except the block a friend is buying that let me know if ur interested
Preludes'R'Us
Aug 24, 2007 06:26 AM
all_motorsi
May 6, 2007 08:55 PM
DanishR
May 14, 2005 11:05 AM
h22aLSD
Nov 18, 2003 09:54 PM
CandyRedHatch
May 5, 2003 08:31 AM
