squeal noise at 1900 rpm??
Old Nov 18, 2003 | 09:24 AM
Rtzx9r's Avatar
GDD 1%
Default squeal noise at 1900 rpm??
Hi-
I have a 98 LS 5 sp w/ 67K. At approx. 1900 rpm (in neutral or moving) I get a squeal noise from my engine bay area. It is only noticable with the window down, and comes on/goes off each time the engine speed goes through the 1800-1900 rpm range. It does not occur at any other speeds, and sounds like a bad belt- but the belts look ok.
Any help would be great. Thanks!!
Old Nov 18, 2003 | 09:26 AM
P1mpSlap's Avatar
If you think it's a belt readjust tension on the belts to make sure they aren't slipping. Just b/c the belt doesn't look worn doesn't mean there isn't correct tension on it.
Old Nov 18, 2003 | 09:28 AM
Rtzx9r's Avatar
GDD 1%
Default Re: (P1mpSlap)
would a belt squeal at just a very small rpm window though???
Old Nov 18, 2003 | 09:30 AM
P1mpSlap's Avatar
Default Re: (Rtzx9r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rtzx9r &raquo;</TD></TR><TR><TD CLASS="quote">would a belt squeal at just a very small rpm window though???</TD></TR></TABLE>
yes
even if it's not a belt, wont hurt to make sure.
Also when was the last time you replaced your brakes? My friends ITR squeals around that RPM then stops and it's his shity brake pads/rotors going out.
Old Nov 18, 2003 | 09:43 AM
Rtzx9r's Avatar
GDD 1%
it is doing it at a complete stop if I rev the engine.
Any other ideas that it could be- timing belt or valves?
Old Nov 18, 2003 | 09:56 AM
LstegB18B2001's Avatar
Mine does the same thing and I was woundering what it was also.......
Old Nov 18, 2003 | 12:05 PM
Rtzx9r's Avatar
GDD 1%
Default Re: (LstegB18B2001)
ttt
Old Nov 18, 2003 | 08:15 PM
BeavisB16's Avatar
ttt
Old Nov 18, 2003 | 11:38 PM
Toadfart's Avatar
Default Re: squeal noise at 1900 rpm?? (Rtzx9r)
I second the tensioner. My friend has a BMW 330i which had the same problem. They adjusted the tensioner.
Old Nov 19, 2003 | 03:09 AM
JDM_Honda_Fiend's Avatar
Yeah your best bet would be to check your belts and make sure they're at the right tension.
Old Nov 22, 2003 | 09:07 PM
YoungOne's Avatar
have a friend gas it until you hear the noise. then take a bottle of water and pour it on the belt, if the squeal goes away, then thats your colprit, if not then, your SOL
Old Nov 23, 2003 | 06:17 AM
94B18B1Teg's Avatar
Default Re: squeal noise at 1900 rpm?? (YoungOne)
have a friend gas it? Dude, the throttle is right there in front of your face, on that big thing called the intake manifold, then the throttle body. If you don't find it, have someone rev it once, so you can see where it is for future reference. And yes, adjust the tensioners before you go buy all new belts like me . I have the same problem...but at lower rpm, and when it rains, holy **** do they squeel at idle all the way through 3000 rpm. So, I'm changing them anyway, and cutting my A/C off, since its about to be winter time.
BPA
May 6, 2013 11:32 AM
jaydem7
Aug 13, 2007 04:14 PM
90efSI
16
Oct 26, 2005 07:36 PM
Maretron
Jul 29, 2005 03:54 PM
Rtzx9r
Nov 18, 2003 04:46 PM
