h22 scater sheld
Old Nov 18, 2003 | 07:33 AM
slamed93si's Avatar
Default h22 scater sheld
how much horse/tourq do i need to make befor i need one
Old Nov 18, 2003 | 08:52 AM
junglerunna's Avatar
Default Re: h22 scater sheld (slamed93si)
What is a "scater sheld"?
Old Nov 18, 2003 | 01:10 PM
Turbogixxer's Avatar
Default Re: h22 scater sheld (junglerunna)
It is a bar (made in to a circle) that going around the axles. If the axles break, the shield catches them and prevents a big accident. It is like a driveshaft loop. You do not need it if you are not running in the 11s (11.99 or quicker if I remember correctly).
Old Nov 18, 2003 | 05:47 PM
Newman's Avatar
New User
Default Re: h22 scater sheld (turbogixxer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer &raquo;</TD></TR><TR><TD CLASS="quote">do not need it if you are not running in the 11s (11.99 or quicker if I remember correctly). </TD></TR></TABLE>
You need a cage if you're running 11.99 or quicker (I know because I've been booted off of a couple of tracks with my old turbo B20 setup and H22A setup w/100 shot of NOS ), and you need a scatter shield when you're running 11.49 and quicker.
Old Nov 19, 2003 | 08:11 AM
slamed93si's Avatar
Default Re: h22 scater sheld (Newman)
ok thats helps alot thanks
Old Nov 19, 2003 | 11:51 AM
EGbeater's Avatar
I thought a scatter shield was to contain an exploding/disintegrating flywheel.
Old Nov 19, 2003 | 01:17 PM
slamed93si's Avatar
Default Re: h22 scater sheld (CRXMR2SM2)
thats what i thought too cause my friend told me that it went around where the tranny bolts to the block cause when u get high hp out of the h22 the flywheel bolts brake off and could come thru the car and kill someone and i dont want that to happen so ne ways how much hp can i put out be for i need one
Old Nov 19, 2003 | 07:18 PM
h22 civ's Avatar
scatter shield is for the clutch/flywheel
And...unless your running near 10's which you won't you don't need one.
Modified by h22 civ at 5:59 PM 11/20/2003
Old Nov 20, 2003 | 06:20 AM
iakona's Avatar
correct and driveshaft loops are for catching stray driveshafts, but only because they could flop around and come into the passenger cabin on dinosaur V8s.
vtec99ej
18
Aug 7, 2007 11:16 PM
94_H22_EG_Hatch
Sep 15, 2006 11:14 AM
Louis53123
Northeast (Sales)
Aug 12, 2006 05:09 PM
