HONDATA
i'm rebuilding the head right now and i'm thinking about going with Hondata instead of the Apex-i VAFC. I started to look at the different models Hondata makes, but i didn't know which one i should get....this is an N/A motor, no turbo....please help and give me some suggestions.
Thanks
Thanks
s100 or 200 would work in his case wouldn't it? If yu go with the N/A setup, I recommend the 3stage rev limit option and of course the data logging capability. I think it would be beneficial to hook up a computer to your car and know what its doing at all times.
Also, a P28 ecu should work too, but since your car is a 93 and OBD1, you might be able to keep your stock computer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeTuner »</TD></TR><TR><TD CLASS="quote">why not a p13?</TD></TR></TABLE>
The p13 can not be used with Hondata
preludes and accords use a different processor than the civics... i think im going back to stock.. what will u offer for my p72 and s200bd? do u need fuel setup? its would have one hell of a base map..
what about who using a p72 without the hondata? is it going to change alot? im asking because im looking to do the same thing and i plan to do a hondata but i need to know which ecu to get first.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedracer9k »</TD></TR><TR><TD CLASS="quote">since it doesn't work with the p13 (which is what i have) i should just go with the VAFC instead?</TD></TR></TABLE>
NO! you should sell your p13, to make some money back.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastludeh22 »</TD></TR><TR><TD CLASS="quote">
NO! you should sell your p13, to make some money back.</TD></TR></TABLE>
Yeah, hondata would be way better than buying a V-FAC for $300-400..... That's about how much hondata will cost then, if you sell you ecu for about $100, you can put about $150 more with it and get a p72 ecu.
the p72 comes out of the GSR teg. i believe one of the reasons for using it is to retain the IAB function, along with all the other stuff like vtec actuation, im sure that there are reasons internal wise on the ecu for why it is compatible with the p72 vs. the p13. but my ? is would this ecu need to be used on an H22 that has no IABs lets say on one with an aftermarket IM, like the Skunk2 if it ever comes out?
what kinda of mods are u going to run, will the hondata really give you alot more power in a NA engine?
http://www.cardomain.com/id/boostlee
i've got skunk2 stage 2 cams, cam gears, valve springs, retainers, B&M FPR w/ gauge, with a 9 or 10 lb. flywheel, and i'm thinking about an Exedy Organic clutch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostlee »</TD></TR><TR><TD CLASS="quote">what kinda of mods are u going to run, will the hondata really give you alot more power in a NA engine?
http://www.cardomain.com/id/boostlee </TD></TR></TABLE>
i dont know about a lot more power,
but i know you can get your 1/4 times down using it
which car does the P28 ecu come out of? Which one will be better to get the P28 or P72? SInce my car is OBD1, i'll need to get an OBD1 ECU right? what else is involved with switching the ECU's?
