Finally hit a dynojet... balancer shaft test
Old Nov 18, 2003 | 04:34 AM
satan_srv's Avatar
Default Finally hit a dynojet...
I will and put up the video later today. But I hit a dynojet to put down a baseline before I build my header and a bunch of other stuff.
I hit 214whp and 167wtq SAE on the dynojet pretty happy about it considering I was on a dynapack before. I removed the balancer shaft belt and gained 3hp and 2tq pretty much all the way through VTEC.
I can feel the vibration on the foot now, but it seems the balancer shaft removal affects acceleration the most. It's not just the power gain it's mostly the freeing up of the rotating assembly. I don't know if I will leave it off. but it feels pretty good for now.
Graph and video to come.
Old Nov 18, 2003 | 05:01 AM
CHK4TIX's Avatar
Default Re: Finally hit a dynojet... (satan_srv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv &raquo;</TD></TR><TR><TD CLASS="quote">...I removed the balancer shaft belt and gained 3hp and 2tq pretty much all the way through VTEC.
thats good to know, i took mine off a while ago, have the same feelings, but i got lazy and it hasnt bugged me enough to put it back on.
by the way i cant wait to see the new numbers.
Old Nov 18, 2003 | 05:08 AM
SKDRCR's Avatar
Default Re: Finally hit a dynojet... (CHK4TIX)
Nice numbers man
i don't think it would really be worth it to me to take
the belt off, but hey every horse counts
so is your new dyno gonna be w/an smsp header
Old Nov 18, 2003 | 05:15 AM
satan_srv's Avatar
Default Re: Finally hit a dynojet... (SKDRCR)
it's a custom 4-1 2.5" header. Some dude from PO.com that lives near me, looks promising.
Old Nov 18, 2003 | 07:34 AM
machine4321's Avatar
ummm your getting the vib in the pedal too.....mabye it was just me but it felt like my motor was going to explode after 6500
i have a very badly chiped crank pullye too though mabye that was why
thanks for the test joel ....can you email me some of those pics for the header (if you have them )
Old Nov 18, 2003 | 09:06 AM
SUB-0 H23's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv &raquo;</TD></TR><TR><TD CLASS="quote">I will and put up the video later today. But I hit a dynojet to put down a baseline before I build my header and a bunch of other stuff.
Graph and video to come. </TD></TR></TABLE>
did you get a chance to try out the cai you making?
Old Nov 18, 2003 | 10:06 AM
Daemione's Avatar
Default Re: Finally hit a dynojet... (SUB-0 H23)
Good to finally get a back-to-back on the balance shaft issue. Looking forward to seeing the graph . . . .
Also, somewhat surprising that you made roughly the same power on a dynojet as you did on the dynapack. I forget - how long a pull did you use on the dynapack?
Old Nov 18, 2003 | 10:46 AM
del_parker's Avatar
Default Re: (machine4321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by machine4321 &raquo;</TD></TR><TR><TD CLASS="quote">ummm your getting the vib in the pedal too.....mabye it was just me but it felt like my motor was going to explode after 6500
thanks for the test joel ....can you email me some of those pics for the header (if you have them )</TD></TR></TABLE>
my motor feels like it wants to keep going even though the power is falling off. i need cams!
Old Nov 18, 2003 | 02:50 PM
satan_srv's Avatar
Default Re: Finally hit a dynojet... (Daemione)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daemione &raquo;</TD></TR><TR><TD CLASS="quote">Good to finally get a back-to-back on the balance shaft issue. Looking forward to seeing the graph . . . .
Also, somewhat surprising that you made roughly the same power on a dynojet as you did on the dynapack. I forget - how long a pull did you use on the dynapack?</TD></TR></TABLE>
I have dropped Power steering since then w/ an f20b crnak pulley...probably 3 across the board from that.
Old Nov 18, 2003 | 02:53 PM
biglew's Avatar
Finally a definite answer.
Old Nov 18, 2003 | 03:20 PM
HotWheelz's Avatar
Default Re: (biglew)
no power steering made a huge difference...... to mine...
I allready have the shafts removed and permanatly out.
dyno sheets and video should be interesting to see/hear.. i wana know if my motor sounds like yours
Old Nov 18, 2003 | 04:18 PM
aeolus's Avatar
Default Re: (HotWheelz)
Acceleration was a big difference after removing them,and also for some odd reason,i feel less vibration from my built motor now that from what i had before which was a stock block type s piston rebuild.
Old Nov 18, 2003 | 04:38 PM
JG Luder's Avatar
Default Re: (aeolus)
I'll take my lost 3 hp and live vibration free...
I can always make up that 3 hp by taking a huge **** before I make a run down the track.
Old Nov 18, 2003 | 04:53 PM
junbb1's Avatar
I have dropped Power steering since then w/ an f20b crnak pulley...probably 3 across the board from that.</TD></TR></TABLE>
when i pulled of ps belt on the dyno i picked up 6.8 whp nearly accross the board.
also milage on the motor will cause the numbers to rise a little.
thank you very much for doing the dyno for us. answers a lot of questions and speculation. it makes me feel betyter about the little gains because i wont take mine off. just a personal preference
Old Nov 18, 2003 | 04:55 PM
JG Luder's Avatar
Default Re: Finally hit a dynojet... (junbb1)
yeah, my power steering is M.I.A. too... but that was a turbo piping thing.
Old Nov 18, 2003 | 05:57 PM
spoolinlude's Avatar
I live under a rock
Default Re: Finally hit a dynojet... (Lone Luder)
HA, a 3hp leak huh?
anyway, I always kinda figured the removal wouldn't work wonders on hp like everyone said....
again, glad to see you back lone luder
Old Nov 18, 2003 | 06:00 PM
satan_srv's Avatar
Satan's Dyno 11/18/03
Click for Video
Run 1 vs. 4 Baseline vs. No Balance Shaft Belt
Pretty obvious gains all around.
Some notes:
1) This was done with no fans, we didn't have time to set all them up, hurts numbers somewhat
2) With the belts off there is okay hp/tq gain, but mostly it's felt in acceleration. It's crazy how much faster the car accelerates, taking the drag right off the rotating assembly
3) My cams need to be set to 4500 look at the cam line, it's crazy how much midrange I will be able to pick up with more tuning.
I actually set VTEC to 4800 and made a rudinentary fuel adjustment...as you can see below there is a lot of power to be gained there...but I need to spend a bunch of time messing with the fuel to get it right...so I just left it at 5000 for now.
Old Nov 18, 2003 | 06:23 PM
kb58's Avatar
Banned
Default Re: Finally hit a dynojet... (BolivianFuego)
I really like seeing this sort of thing. Actual data instead of endless anecdotal stories about 'x' hp gains "for sure".
Old Nov 19, 2003 | 12:00 AM
satan_srv's Avatar
Default Re: Finally hit a dynojet... (kb58)
thanks!
next up is a header test, and my new cf intake test...probably in a month
Old Nov 19, 2003 | 12:18 AM
@ries's Avatar
Nice numbers man Can't wait to see what the header & intake do
Old Nov 19, 2003 | 03:40 AM
George Knighton's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv &raquo;</TD></TR><TR><TD CLASS="quote"> I removed the balancer shaft belt and gained 3hp and 2tq pretty much all the way through VTEC.</TD></TR></TABLE>
Thanks very much for taking the time to do this.
People have been talking about the balancer for ages, but this is the first time I've seen a dyno that specifically measures just that.
Old Nov 19, 2003 | 08:11 AM
Goinfasterthanu's Avatar
What all do you have done to your car?
Old Nov 19, 2003 | 01:04 PM
satan_srv's Avatar
Default Re: Finally hit a dynojet... (George Knighton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">
People have been talking about the balancer for ages, but this is the first time I've seen a dyno that specifically measures just that.</TD></TR></TABLE>
Yeah I had to specifically go to the dyno with no timing cover on hehe....
For the other guy the full setup is:
AEM CAI
64mm TB
Hondata IM Gasket
AEM FPR
RC 370cc injectors
TechTom P72 tined for my old motor
Apexi V-AFC
H22A1 head ported by Top Power Racing , valve deshrouding blah blah
Crower Stage 3 cams
Skunk2 cam gears
Jun Valvesprings
Jun Titanium Retainers
H22A4 Block
89mm LA sleeves
H22A4 stock crank balanced
Crower ProBillet H22A I-Beam Rods
ENDYN Rollerwave 11.89:1 pistons and rings
Stock Head Gasket bored to 89mm
Prodrive oil pump gears
Power Enterprise Super Strong Timing Belt
H23 manual tensioner
F20B Crank Pulley no PS
Removed A/C
Trust/GReddy SS Header
Random Technologies High Flow Cat
GReddy Power Extreme 2.5" catback
Clutchmasters Ultralight Flywheel
Clutchmasters stage 3 clutch
Accord Euro-R Transmission w/ LSD
Old Nov 19, 2003 | 02:17 PM
JG Luder's Avatar
With all of that, I'm surprised you aren't putting down more power.
Old Nov 19, 2003 | 02:37 PM
Cottonwoodz's Avatar
What engine is the F20B again?
