HELP!! melted number one piston
Old Nov 17, 2003 | 10:22 PM
drivfastr's Avatar
Default HELP!! melted number one piston
heres my situation i recently finshed installing a b18c1 in my ek, about 2 days ago i was driving on the freeway when i thought i blew a head gasket.The next day I pull the head off and there is a hole burnt in the side of the #1 piston. upon inspection of the head it will need to be milled to remove gouges from piston material.The cylinder walls do not appear to be gouged, however there is a silvery metallic buildup in them where the piston burned thru. Aparently i got screwed with the motor that i have because the guy who ran it before me sprayed it to the moon and back i wish i had pics of the block and head but any advise or help would be GREATLY appreciated
Old Nov 18, 2003 | 06:20 AM
mr.beeks's Avatar
Default Re: HELP!! melted number one piston (drivfastr)
it sounds like he already had the hole there and patch it up
in wich wont last
and sold it to you so regular pistons dont melt they break.
I suggest you go chasing after the guy that sold the block to you!
Old Nov 18, 2003 | 06:54 AM
drivfastr's Avatar
Default Re: HELP!! melted number one piston (big reds)
thanks alot for the reply, it doesn't appear to be a patch though, it almost looks like one of the rings or part or the skirt adhered to the cylinder wall any more advise welcome oh yeah and i don't really have much recourse in going after the gut who sold it to me start up only
Old Nov 18, 2003 | 07:21 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drivfastr &raquo;</TD></TR><TR><TD CLASS="quote">any more advise </TD></TR></TABLE>
Mic the cylinder to make sure it's not damaged, replace the piston and keep the nitrous to a reasonable level.
Old Nov 18, 2003 | 07:26 AM
drivfastr's Avatar
Default Re: HELP!! melted number one piston (Chiovnidca)
thanks alot, i got the motor from JDM honda parts whoever they got it from sprayed the **** out of it
97grnrs
Apr 10, 2007 05:12 PM
MatHadder
12
Mar 4, 2007 02:59 PM
4gencivicef9
Jun 27, 2006 05:51 PM
NyQuiL
May 5, 2004 07:42 PM
