Start Car, screeching sound....?
when i start my car, i get a high pitched screeching sound that seems to be in line with the timing belt and i sometimes get that screech when i shift gears, i am doing the minime and puttting on a new timing belt, do you think that is the problem?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Op IVY Si »</TD></TR><TR><TD CLASS="quote">belts are slipping.. if your swapping motors it maybe a good time to replace them anyway!!</TD></TR></TABLE>
thanks, i had a feeling, its ok though i am putting on the y8 head on my y7 so the y8 timing belt is on its way!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverGSR99 »</TD></TR><TR><TD CLASS="quote">Its the timing belt , my brothers Del Sol did the Same thing when he turned the car on a annoying scretch came on.</TD></TR></TABLE>
did the screech go away after a while
If your timing belt is slipping, you got more problems than you think. Probably your a/c or power streering belts. A little belt dressing will work fine, no wd-40 please.
hmtcrxsir
Nov 4, 2005 10:07 PM
