D17 question.... I searched...
I just had a quick question... I know that the d series parts are supposed to fit other d series engines but will a d16 header fit on a d17 engine... any help would be great... thanks
shane
shane
i dont think they will. because of the design and all. i would just find a pic of a d16 header and compare with a pic of a d17 header.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">Yep, they are completley different, they face different directions.</TD></TR></TABLE>
i though it was only diffrent on the k20/k24. where the intake is upfront. or is that not what you mean by this?
i didnt think the d17 was rotated 180deg from other d-series motors... could you perhaps find something to back this up (for knowledge's sake)
Sorry guys, looks like I got confused and was thinking about a K series motor for some reason...whoops.
EDIT: Aernt the deck heights different though??
I was just wondering if the bolt pattern is the same because i've got a greddy turbo kit for an eg and my friend has a 2003 civic.... i was wondering if the manifold would work? does anyone have any pics of the newer civic engine bays? tia
fyi, this is what this guy had to say. i have no idea who he is or how credible this is but it's interesting. it was pasted from spade's immortal d series thread, page 5.
https://honda-tech.com/zero...age=5
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seekerONE »</TD></TR><TR><TD CLASS="quote">
ok guys...here is the lowdown on the d17 (2001+ civic) engine
i am a tech at a honda dealer and we had to change out a d17 for a block problem so i took a little time and researched a few things and my conclusion is this...this motor sucks as far as swapping into any other d series car. don't even give another thought as to using this in anything other than 2001+civic...it won't work
mounts are radically different. the crank uses different size journals and even larger bore crank pulley.piston are the smallest, lightest and probable the weakest of any d pistons i have seen. the cylinder head has no provision for distributor installation and very different thermostat housing and coolant outlet. intake manifold is plastic and designed for saving space. injectors are the new smaller size and fuel system is returnless. the vtec for the EX model is the same vtec operation as the older HX head and even though this is a d-series engine honda has seen fit to change the head and block enough so that older components won't line up. the d17 is truley the blacksheep of the d-series. as far as i am concerned it is useless to anyone other than 2001+ civic owners</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue »</TD></TR><TR><TD CLASS="quote">haha sorry man, but its true
Someone does have a nice turbo one on here though. Props to him
Because it's hard to put a turbocharger on anything?
</TD></TR></TABLE>Because it's hard to put a turbocharger on anything?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">
Because it's hard to put a turbocharger on anything?</TD></TR></TABLE>
I thought something about the returnless fuel system made it harder than **** to do. I don't really know how the returnless fuel system works, so I can't say for sure though.
hmm... heres my D17 FULL 4-1 hp racing header
and dennn my new one.
d17
wit some head work(p&p) etc, new rods and pistons.. the D17 can handle 14psi of boost daily putting down over 300hp
d17
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mchotdog »</TD></TR><TR><TD CLASS="quote">Stock vs Stock the D17 is better than the D16. But when both engines are heavily modded (turbo) the D16 will respond better.</TD></TR></TABLE>
Anything to back that up?
hahaha.. says mr 17 posts..
read what i posted above. just cause its displacement is 0.1L bigger doesn't make it a better motor.. come on. a PLASTIC intake manifold????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwn7 »</TD></TR><TR><TD CLASS="quote">hahaha.. says mr 17 posts..?</TD></TR></TABLE>
He's been a member 4 times as long as you.....when are you guys going to learn that post count doesnt mean jack crap??
