need help...loud "whirrr"ing sound
Old Nov 17, 2003 | 03:25 PM
htownteg's Avatar
Default need help...loud "whirrr"ing sound
theres a loud "whirr"ing sound coming from the cam gear, timing belt, and pulley area...its gets louder when i give it more gas..im stumped..also when im driving in gear it feels like something slowing the car down no matter how much gas i give it then it lets go and jerks the car
Old Nov 17, 2003 | 03:28 PM
Jimmy's Avatar
Global Moderator
Default Re: need help...loud "whirrr"ing sound (htownteg)
Gee...did your timing belt snap?
Old Nov 17, 2003 | 04:59 PM
htownteg's Avatar
Default Re: need help...loud "whirrr"ing sound (USDMDC2)
nope
Old Nov 17, 2003 | 08:35 PM
cstem's Avatar
I just had this happen to me. It turned out to be a bad a/c idler pulley that commited suicide by throwing itself down the freeway, but hte noise went away. If no a/c on your car, check the following- power steering fluid level, alternator bearing (alt gets really hot to touch) and I was told to check if timing belt is getting loose which should not be a problem if replaced recently.
Old Nov 18, 2003 | 03:16 AM
htownteg's Avatar
Default Re: need help...loud "whirrr"ing sound (cstem)
yea that kind of makes sense because it could be the pulley pulling the rpms down ...power steering fluid is fine...if it is the alternator that means i have to replace the whole alternator right...i dont want my ac idler pulley to throw its self on the freeway...
Old Nov 18, 2003 | 06:25 AM
cstem's Avatar
It was actually the idler pulley itself that came off. I assume since I just bought the car and the dope told me he just did a bunch of a/c work (did not care as it's coming out anyway) that maybe he did not properly tighten or install the pulley. Rub your fingers on the drive surfaces of the belts-WITH THE ENGINE OFF- and see if any of them have chalky black stuff on them. I would go with that drive system then.
Old Nov 18, 2003 | 05:47 PM
htownteg's Avatar
ok im beginning to think it was just me hearing the noises because i wanted to believe it was the pulleys but now that i think about it, it could be something in the fuel system...my car isnt idling right and it sputters when i accelerate to fast
Inextricabledrvr
Nov 16, 2009 05:29 PM
teamvirus
Honda Civic (2001 - 2005)
Jun 1, 2009 06:49 AM
GSRNetics
Oct 19, 2006 09:03 PM
NoVALude
Aug 21, 2006 08:26 AM
