h22 tb and b20 tb help me out someone
Okay so i have a h22a4 in my hatch and my tp sensor snaped when the motor kicked back and hit a fuel line that runs behind it. I have a b20z upper intake manifold with the tb and sensor on it. I was going to put the tb on the h22 because it all appears to be the exact same. Can anyone verify if this will work or not id appreciate ur help.....or is there a way to get the riveted tp sensor off and onto my h22 one....
You can use a dremel to cut a groove into the heads of the screws so you can fit a flat blade screw driver. Or you can use one of those stripped head removal bits to get them out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gdrum »</TD></TR><TR><TD CLASS="quote">oh so its threaded???? its not like a rivett?</TD></TR></TABLE>
Correct
Correct
89B16HBSBETTERHALF
17
Sep 3, 2002 08:26 PM
