Carsound
Old Nov 17, 2003 | 11:20 AM
jfoster's Avatar
Default Carsound
Is this the best deal that can be had on a carsound high flow cat?
http://cgi.ebay.com/ebaymotors...73386
I need a 2.5" one.
Thanks, JFoster
Old Nov 17, 2003 | 11:49 AM
yesbuy's Avatar
Default Re: Carsound (jfoster)
do thier cats meet obd2 ?????
Old Nov 17, 2003 | 11:53 AM
P1mpSlap's Avatar
yes they are OBD2 compliant, however you need to have O2 sensor bungs welded in. Also those ebay carsound cats do not come with flanges, so you'll have to get those welded on too.
When it's all said and one, you might as well buy one from SMSP.
Old Nov 17, 2003 | 11:59 AM
yesbuy's Avatar
Default Re: (P1mpSlap)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P1mpSlap &raquo;</TD></TR><TR><TD CLASS="quote">yes they are OBD2 compliant, however you need to have O2 sensor bungs welded in. Also those ebay carsound cats do not come with flanges, so you'll have to get those welded on too.
When it's all said and one, you might as well buy one from SMSP.</TD></TR></TABLE>
what is smsp, i need a high flow cat!!! im buying a cat-back and currently i have custom pipping with out a cat so what should i do buy a cat or a o2 simulator
Old Nov 17, 2003 | 12:03 PM
andrewM's Avatar
Default Re: (yesbuy)
if u have custom piping then u can just have the cat welded on to the pipe without the flanges. if u want to use the o2 sensors then u are gonna have to have the threads for the sensors put into the pipe.
m R g S r's Avatar
Why bother with a cat if you already removed it?
Old Nov 17, 2003 | 02:44 PM
i2un's Avatar
E-bay is $31.95 min bid + $15 shipping and handling = $46.95. No O2 bungs or flanges.
Like P1mpSlap said you may be better off getting something that is just plug and play from SMSP or whatever.
Ps. I can get you the same universal one that's on ebay for a little cheaper (2.5 in). If you need it. Let me know?
Old Nov 17, 2003 | 02:58 PM
Steve04SVT's Avatar
Default Re: (andrewM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andrewM &raquo;</TD></TR><TR><TD CLASS="quote">if u have custom piping then u can just have the cat welded on to the pipe without the flanges. if u want to use the o2 sensors then u are gonna have to have the threads for the sensors put into the pipe.</TD></TR></TABLE>
Bad idea! The exhaust has to give a little to compensate the for movement of the motor. Once you weld the cat. to the piping, you make it to rigid that you end up breaking bolts, rubber hangers, or even the weld themselves. I've worked at a speed shop and I use to see people come in who had their stuff welded like this, and they wanted to get it fixed. This one guy kept developing a leak on the header flange. We took out the cat and installed the proper flanges. Needless to say the problem got fixed. Honda puts a lot of research into the development of their parts and systems in their cars. They put all the ball and socket style flanges on cars for a reason. IMO, save yourself some cash and get it done right the first time around.
Old Nov 17, 2003 | 03:01 PM
P1mpSlap's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yesbuy &raquo;</TD></TR><TR><TD CLASS="quote">
what is smsp, i need a high flow cat!!! im buying a cat-back and currently i have custom pipping with out a cat so what should i do buy a cat or a o2 simulator</TD></TR></TABLE>
https://honda-tech.com/zero...=4028
Dave is legit. Good guy
Old Nov 17, 2003 | 03:07 PM
jfoster's Avatar
Default Re: (i2un)
Yesbuy, smsp or sms products is a custom exhaust builder. I was told to send an IM to the username smsp here on HT.com for a price quote, so I did. Since if I went the ebay route I would still have to pay S&H and get a flange to make it fit the 2.5" collector on my jun header, and pay S&H on that and apparently still need it to have a bung. I did not know I needed it to have a bung. I thought I just had one in the collector and that was it. Anyway, depending on what SMSP says that may be the way I go.
Old Nov 17, 2003 | 06:12 PM
yesbuy's Avatar
yah at first i didn't want to spend alot of money but now im getting a new header cat and cat-back!!! already sold my muffler just looking for a good deal! and i want my cel light to go away when i take my car out of storage, im not in any rush cause the car has 5 more months until it comes out!
Old Nov 17, 2003 | 08:26 PM
jfoster's Avatar
I know what you mean. I started out planning on getting a $300 header and then holding off for awhile. Now I've bought a $550 header and I'm searching for a cat and a muffler to go along with all new 2.5" piping. What do you mean cel light? Is that a warning light on your dash? I can't deal with that.
Old Nov 20, 2003 | 12:46 PM
Muckman's Avatar
Moderator in Chief
Default Re: (Steve00GSR)
Two words: Flex pipe
Old Nov 20, 2003 | 01:05 PM
jfoster's Avatar
Default Re: (Muckman)
Thanks for the replies. Kteller8 and SMSP both quoted me $185 for a 2.5" cat with flanges and bung. I am sure their stuff is top quality but my goal is budget. As of now my plans are to get the cat here:
for $47 shipped. Performance curve also has the muffler I want
http://cgi.ebay.com/ebaymotors...73545
for $43+$10s&h. I plan to get my flanges here:
http://www.jcwhitney.com/webap...10101
And the bung for the cat here:
http://store.summitracing.com/...3&y=8
And the bends here
My total on the cat with the flanges and bung + $15 for the muffler shop to weld it should be around $75. I am supplying the muffler, mandrel bends and cat, and the muffler guy is supplying the straight sections and welding it all for around $125. Any comments are welcome, if you spot a better price let me know.I still have to educate myself on and select a resonator. I hope the links I am posting will help someone else looking for this kind of stuff.Thanks, JFoster
Xx D-MAN xX
Aug 31, 2004 07:17 AM
2lobes1engine
11
May 11, 2004 03:14 PM
SIK IN DA HED
Dec 3, 2003 07:32 PM
Leb_CRX
Sep 30, 2003 06:17 PM
B00ST2nR
Feb 19, 2003 05:37 PM
