Type-S pistons question
Old Nov 17, 2003 | 10:59 AM
scrubachu's Avatar
Default Type-S pistons question
i was wondering if the rings from the regular jdm h22 pistons or the regular USDM piston rings would work on my new type-s pistons?? im trying to find a set of type-s piston rings, but hey arent very common. i may just order them from honda, but i was hoping to save some cash by finding out if the other rings will work. thanks
Old Nov 17, 2003 | 11:00 AM
Fly1865's Avatar
Default Re: Type-S pistons question (scrubachu)
I used US rings on my Type-S piston
Old Nov 17, 2003 | 01:16 PM
scrubachu's Avatar
Default Re: Type-S pistons question (Fly1865)
have you checked your compression?
Old Nov 17, 2003 | 08:05 PM
scrubachu's Avatar
bump please
Old Nov 17, 2003 | 08:16 PM
NXLude's Avatar
you can use either one....Id strongly recommend type s rings which are easy to find and intended for those pistons
Old Nov 17, 2003 | 08:20 PM
georgiajdm's Avatar
if the pistons are the same bore just use the us ones. just make sure they seal tightly when you slip them in.
Old Nov 18, 2003 | 09:42 AM
icbmatt's Avatar
Fly1865,
What is your CR after the piston install?
Old Nov 18, 2003 | 11:42 AM
Fly1865's Avatar
Default Re: (cmgi8@yahoo.com)
I haven't had a chance to do one, I don't own one and i've been kinda lazy to go buy one cause i don't want buy a crappy one.
Old Nov 19, 2003 | 03:22 PM
AndyD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fly1865 &raquo;</TD></TR><TR><TD CLASS="quote">I used US rings on my Type-S piston</TD></TR></TABLE>
So is there any difference between the USDM rings and the Type S piston rings??
Old Nov 19, 2003 | 08:27 PM
Anhjockz's Avatar
Default Re: Type-S pistons question (AndyD)
well just stick with the ring of the type of piston much safer i think but i can be wrong..... its just the ring well find some type s rings then just my info
this is wack indeed indeed hahhahahah\
Old Nov 19, 2003 | 08:30 PM
satan_srv's Avatar
Default Re: Type-S pistons question (Anhjockz)
I highly doubt there is anything special about a type-s piston ring.
Old Nov 20, 2003 | 12:07 PM
flyrod's Avatar
Default Re: Type-S pistons question (satan_srv)
I used plain USDM H22 honda rings from the dealer with my type S pistons. Seems to work fine. All the measurements were within spec. If you use 0.25 mm oversize pistons, be sure to get the oversize rings...
thugsbryan
Engine Machining & Assembly
Apr 5, 2018 06:39 AM
ziurek filmus
Apr 16, 2017 10:17 PM
crex23
Feb 2, 2006 05:41 PM
HondaGuy02
May 22, 2005 01:47 PM
ssr_h22
Sep 6, 2004 09:21 AM
