Doing a hydro clutch setup in 89' crx
Old Nov 17, 2003 | 10:08 AM
tgreaves's Avatar
Default Doing a hydro clutch setup in 89' crx
How hard would it be to do a hydro clutch setup in a crx.. I dont mean a cable to hydro conversion, I mean using an actual clutch master cylinder and all the other stuff to do it.. Do I just mount the clutch master cylinder on the firewall and run hydro lines down to the tranny into the slave cylinder or is there more to it then that..
Old Nov 17, 2003 | 10:24 AM
wickedEFguy's Avatar
Default Re: Doing a hydro clutch setup in 89' crx (tgreaves)
nope you don't need to do that at all. Just make sure you get the hasport cable-->Hydro conversion and everything should be fairly easy.
Old Nov 17, 2003 | 10:37 AM
tgreaves's Avatar
Default Re: Doing a hydro clutch setup in 89' crx (wicked B16)
I didnt want to do the cable to hydro conversion.. I'd much rather put the entire hydro setup and use it that way..
Old Nov 17, 2003 | 11:20 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">I didnt want to do the cable to hydro conversion.. I'd much rather put the entire hydro setup and use it that way..</TD></TR></TABLE>
honestly it's a waste of money and not worth it. Besides you have a better feel with a cable tranny then a hydro. Why do you think most ppl go to cable?
Old Nov 17, 2003 | 11:42 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wicked B16 &raquo;</TD></TR><TR><TD CLASS="quote">
honestly it's a waste of money and not worth it. Besides you have a better feel with a cable tranny then a hydro. Why do you think most ppl go to cable?</TD></TR></TABLE>
Are you saying you have a better feel with a cable tranny or a better feel with a cable to hydro conversion on a hydro tranny..
Old Nov 17, 2003 | 12:30 PM
well if you have a cable --&gt;hydro conversion then you still have a cable feel. I like the feel of cable since you can get more of a feel for the tranny itself. Hydro tranny is a lot easier to push in put the feel isn't the same
diamondstarsforever
35
Oct 11, 2010 01:15 AM
fatboys_ef9
Transmission & Drivetrain
Feb 23, 2010 06:29 PM
Convert
Feb 1, 2009 09:51 PM
JrOz
16
Sep 27, 2007 11:20 AM
88 yellow crx
Jun 7, 2007 10:44 AM
