How to wire up Y8 IAC to EF (D16A6) EACV harness?
Old Nov 17, 2003 | 09:57 AM
EGbeater's Avatar
Default How to wire up Y8 IAC to EF (D16A6) EACV harness?
I'm almost done putting a Y8 head and manifold on my D16A6 block into a '89 CRX Si. I can't figure out this last obstacle.
I know that the modules with a two-wire connector on the pass. side back of the manifolds serve the same function, but they have different connectors. They also don't have the same bolt pattern, so I can't just swap the old EACV to the newer manifold (correct me if I'm wrong).
I can cut off the old connector put new female spade connectors into the Honda connector on the Y8 manifold, but how do I tell what wire goes where? I figure it matters . . . I don't want to just guess, do it backwards and smoke the ECU or something.
Thanks in advance!
Old Nov 17, 2003 | 10:44 AM
wickedEFguy's Avatar
Default Re: How to wire up Y8 IAC to EF (D16A6) EACV harness? (CRXMR2SM2)
ok the 2 wires that you need to look for on the CRX harness are BLK/YEL (A17) and BLU/YEL (C2). They should be the same color as the Y8 head.
Old Nov 18, 2003 | 06:04 AM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
if i remember right the iacv/eacv from the manual y8 manifold and the a6 manifold both have the same 2 wire plug...
the plug from the a6 harness should plug right into the y8 iacv.
Old Nov 18, 2003 | 10:24 AM
EGbeater's Avatar
Default Re: How to wire up Y8 IAC to EF (fastcrxsi90)
Thnx for your replies wickedB16 and fastcrxsi90, but the connectors are in fact different. Since I don't have the wire that used to plug into the IAC on the Y8 IM, I can't just reference it by color.
I know that all D16A6's are not necessarily exactly the same in terms of wiring connectors - a friend of mine has a '90 Civic Si and we swapped it out for another junkyard D16A6 b/c it was burning tons of oil.
We found that the harness going to the injector resistor box had different shaped connectors, and even had a different # of wires in it. We tried to rig it together but we had a check engine light. After the old wire harness was swapped off the old engine onto the new one, it worked fine then though.
Old Nov 18, 2003 | 09:19 PM
EGbeater's Avatar
Default Re: OK, I'm an idiot . . .
You guys were right - it does plug in. The connector on the Y8 IAC valve seemed to have an adapter on it - once I figured out I could remove that, and that the actual connector was underneath it, the old A6 EACV connector plugged right in.
freddy chavez
14
May 30, 2013 08:55 PM
blknpurple
28
Feb 18, 2013 04:44 PM
Mr. 1582
Oct 15, 2003 06:18 AM
g2turbo
Jul 2, 2003 11:58 PM
SPOON_BeIgHtEeNsEe
Jan 21, 2003 06:50 AM
