Anybody ever piece together their own turbo kit.. got plans..
Old Nov 17, 2003 | 08:49 AM
tfalconier's Avatar
Default Anybody ever piece together their own turbo kit.. got plans..
i have a 93 ex 5 speed, and i want to swap motors, im not sure on what kinda dohc motor im going to swap to, but thats besides the point. i have done alot of turbo 2.3 fords and have LOTS of parts left over, spare intercoolers, intercooler pipes, turbos, injectors, and so on. i want to boost w-e motor goes in there, i know im going to need a custom comp, bigger fuel pump and regulator, turbo exhaust manifold, and bigger injectors because i dont think you can make ford injectors work with honda. Has anybody ever done their own turbo kit? What motor would be the best for a turbo?
Old Nov 17, 2003 | 08:51 AM
1 point 6's Avatar
Down Since Day 1
Community Builder
Community Influencer
Default Re: Anybody ever piece together their own turbo kit.. got plans.. (tfalconier)
This should get a better response in the Forced Induction forum, but here is some usefull info on a pieced together kit.
This was taken from Honda Tuning magazine April issue. I couldnt find it online so i decided to hand type it. They do have a full step install guide in the mag, which is awesome.
<FONT SIZE="4"><FONT COLOR="darkblue">SHOPPING LIST:</FONT> </FONT>
<FONT COLOR="purple">From Local Performance Shop</FONT>
Three 2.23 inch U-bend steel $17
One 2.5 inch 90 degree aluminized bend - $25
One down pipe flange $10
One down pipe gasket $8
One 1G blow off valve flange $10 (1st gen eclipse)
One 1G blow off valve gasket $4 (1st gen eclipse)
One 6mm gasket $3
One turbo-to-oxygen sensor housing gasket $5
One oil return line new $55 used $10 (may have to widen the opening)
One oil return gasket $1
One silicone 2.25 inch to 2 inch reducer hose $18
One foot of rubber 2.25 inch hose - $12 per foot
Nine 2.75 inch heavy duty clamps $2 each
One 3 inch heavy duty clamp - $2.50
One 1G blow off valve $90 new $5-$40 used (1st gen eclipse)
One 2G T25 Turbo - $25-$150 (2nd gen eclipse)
One 1G oxygen sensor housing $10-$20 (1st gen eclipse)
One 2G stock intercooler core - $10-$50 (2nd gen eclipse)
<FONT COLOR="purple">From Local Salvage Yard</FONT>
One HF CRX manifold $20 to $50
<FONT COLOR="purple">Local Auto Parts Store (pep boys/autozone)</FONT>
One 60 inch long .25 hard line $1.69
One 1/8 inch NPT male to male fitting $1.49
One 1/8 inch NPT femal "T" fitting $2.19
One 1/8 inch male to 1/4 inch pipe female fitting $1.49
One 1/2 inch ID rubber hose, 1 foot $1.99
One can of high temp engine paint $3.99
Four quarts of oil $9.16
One oil filter $4.15
They did mention the adapter plate in the article, but not on the list, so here is the specs on that, word for word from the article.
Using the HF manifold as a guide, center it on a piece of .75 x 4 x 5 inche flat steel plate that is roughly big enough to mate the header and turbo. Mark and center punch the four holes on the manifold. Drill and tap with a 10mm x 1.25mm tap .5 inch deep for all four holes, but do NOT go all the way through. If you prefer you can skip this process and weld the plate directly to the manifold. But i know some people dont have welders. Here is a pic of the adapter plate
<FONT COLOR="purple">Tools Needed</FONT>
Basic mechanics tools - Sockets, wrenches, etc.
Grinder
Tape measure
Center hole punch
Die Grinder
Drill pess/hand drill
Drill bits
2 inch hole saw
Welder
The least we spent was $225 & the most was about $560
Check out http://www.homemadeturbo.com, they have some good articles and good resources if your going to tackle this by yourself.
Old Nov 17, 2003 | 09:44 AM
541delSol's Avatar
^Link isn't working, but I was toying with this idea and was talkting to a mechanic buddy of mine, who said that instead of looking for a 2G DSM turbo, look into some Chryslers from the late 80's early 90's. He said they are a little bit smaller (spool up faster) and because they were on sedans, they would probably be in better shape (not ran as hard). I don't know alot on the subject, just passing on hear-say.
Old Nov 17, 2003 | 09:45 AM
DaX's Avatar
DaX
Loved
Community Favorite
Old Nov 17, 2003 | 09:47 AM
DaX's Avatar
DaX
Loved
Community Favorite
and yeah, the local junk yard sells the turbos off the chryslers for $50 a piece, most of which look to be in decent shape.
Old Nov 17, 2003 | 10:27 AM
nate_d's Avatar
try using the search for homemade turbo setups
Old Nov 17, 2003 | 10:47 AM
righteyeblind's Avatar
Default Re: Anybody ever piece together their own turbo kit.. got plans.. (dak)
Smaller than a t-25???A t-25 turbo from a 2g is very small and spools up real quick. I think your injectors from your ford will work. But all you need for fuel is a 12:1 fmu...no pump, injectors. I ran 12psi on my d16z6 with only an fmu for fuel mods. I am at 5000 ft so maybe only 6-8psi at sea level on a cold night
f20b jones
Jan 24, 2011 11:24 PM
Powelly
Dec 13, 2008 06:51 AM
tfalconier
Nov 19, 2003 06:55 AM
turbo Si
Jan 27, 2003 07:06 AM
