Fuel in cylinder 4
My car has been putt putting at low RPM's and then at 4 it will finally drive correctly. I pulled open the spark plug "caps" and found what I think is gas in cylinder 4. I cleaned the engine bay 2 days ago and the engine started acting weird yesterday. Do I just soak up the excess fuel and dry the spark plug? Buy a new spark plug? Please help.
unplug the spark plug, leave it out overnight to dry things out, preferrably in a garage (humidity outside could compound the problem) and make sure no dust or debris can get in there...if that doesn't work you prolly have a much bigger problem...
Ok I let it air out, then I let the cylinder air out for a few hours. Now the car won't start, it turns over and it almsot started one time but quickly died. HELP!!!
TravisBiggie
Sep 29, 2013 06:33 PM
slowwcivic
May 25, 2011 06:18 AM
