gm synchromesh vs redline
Old Nov 17, 2003 | 08:10 AM
lke2drvgsr's Avatar
Default gm synchromesh vs redline
part #12377916, gm synchromesh friction modified had aweful 3rd/4th gear grinding and couldnt use 1st gear half the time (this was with REDLINE!! which SUCKED!!!) gm synchromesh makes 1st gear a breeze, and all the other gears nice and smooth with no 3rd gear grinds. very very satisfied with this stuff sorry, just happy, had to share
Old Nov 17, 2003 | 08:20 AM
wanna b R's Avatar
Default Re: gm synchromesh vs redline (lke2drvgsr)
gm synchromesh
Old Nov 17, 2003 | 08:22 AM
Full Race EG's Avatar
Default Re: gm synchromesh vs redline (wanna b R)
Old Nov 17, 2003 | 09:09 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I also give it
I had about 15K on my Honda MTF and it came out looking almost new when I drained it. But I figured since I was going to have my car on a lift and could get the Synchromesh for cheap, I'd give it a shot.
My current setup as far as shifting is: generic short throw (same height as stock, very short throw), ES bushings, stock shift ****, GM friction modified Synchromesh. I must say, it's a joy to drive every time I shift gears.
Old Nov 17, 2003 | 10:20 AM
lke2drvgsr's Avatar
Default Re: gm synchromesh vs redline (PatrickGSR94)
yea ive got a jdm itr tranny (4.78 fd+lsd) so i dont have the $ to buy a new tranny... i tried this stuff, and the grinds went away. not to mention, i can now shift into first and my other gears are smooth.
Old Nov 17, 2003 | 10:48 AM
oMek's Avatar
its great stuff, but over time i think it starts to brake down or something. my gears where smoth as butter and now they are starting to get hard again
Old Nov 17, 2003 | 12:00 PM
Community Builder
Default Re: gm synchromesh vs redline (oMekoneDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oMekoneDC2 &raquo;</TD></TR><TR><TD CLASS="quote">its great stuff, but over time i think it starts to brake down or something. my gears where smoth as butter and now they are starting to get hard again</TD></TR></TABLE>
uhh well you do have to change tranny fluid, just like engine oil... just not as often. I've been changing mine every 15K-20K miles.
Old Nov 17, 2003 | 12:47 PM
lke2drvgsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">
uhh well you do have to change tranny fluid, just like engine oil</TD></TR></TABLE>
lol
Old Nov 17, 2003 | 12:50 PM
fivespeedintegra's Avatar
i've got GM in the tranny too...butter every shift
Old Nov 17, 2003 | 12:51 PM
CNSK's Avatar
uhh well you do have to change tranny fluid, just like engine oil... just not as often. I've been changing mine every 15K-20K miles.</TD></TR></TABLE>
dang....last time i changed was at 80,000 miles. Now it has another 35,000. I must changed it huh.....maybe GM this time.
Old Nov 17, 2003 | 01:25 PM
Rad_Teg's Avatar
Default Re: gm synchromesh vs redline (DrMartin)
Where did you guys get your gm synchromesh at? Dealer?
Old Nov 17, 2003 | 01:29 PM
Default Re: gm synchromesh vs redline (Rad_Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rad_Teg &raquo;</TD></TR><TR><TD CLASS="quote">Where did you guys get your gm synchromesh at? Dealer?</TD></TR></TABLE>
yep...i went to a chevy dealer across from where i work...paid $9.50 a quart.
Old Nov 17, 2003 | 01:32 PM
lke2drvgsr's Avatar
Default Re: gm synchromesh vs redline (fivespeedintegra)
all chevy dealers should have it... any gm dealer should, but most don't it's out there though, i went to over a dozen dealerships till i found it
Old Nov 17, 2003 | 02:59 PM
Hate's Avatar
i need some of this stuff...you just add a quart with your MTF when changing it?
Old Nov 17, 2003 | 04:24 PM
lke2drvgsr's Avatar
Default Re: (Hate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hate &raquo;</TD></TR><TR><TD CLASS="quote">i need some of this stuff...you just add a quart with your MTF when changing it?</TD></TR></TABLE>
hell no. buy 3 quarts of this stuff, poor ~2.5 quarts (whatever the tranny holds)... dont mix it w/anything else.. gm synchromesh friction modified part # 12377916 tahts all u need, forget mtf or redline or any of that terrible ****.
Old Nov 17, 2003 | 05:33 PM
patdemps's Avatar
Default Re: (lke2drvgsr)
GM syncromesh friction modified
I put it into my ITR tranny with 4.785 FD and Kaaz LSD. Any noise or anything else went away. It shifts perfect into every gear and even into first while moving. I would suggest it to anyone. I am about to sell my tranny setup because Im going turbo and need a GSR tranny with lsd. But ill still use the GM syncromesh FM, it worked wonders. I heard change your tranny fluid every 2nd oil change. So around 6k. I let mine go about 5-6k. If you like your car, treat it like you would want to be treated. Change it as often as you can (5k-15k), to keep the life of your tranny.....
Old Nov 17, 2003 | 05:40 PM
Community Builder
Default Re: (patdemps)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by patdemps &raquo;</TD></TR><TR><TD CLASS="quote">I heard change your tranny fluid every 2nd oil change. So around 6k. I let mine go about 5-6k. If you like your car, treat it like you would want to be treated. Change it as often as you can (5k-15k), to keep the life of your tranny.....</TD></TR></TABLE>
That's a little over the top, like I said I drained my Honda MTF after only 15K miles and it still looked brand new. But hey if you can afford $10/qt. every 6K miles, more power to ya.
DCRB
Transmission & Drivetrain
Apr 5, 2019 04:50 PM
dondy07
May 13, 2017 05:18 PM
bustedasscivic
Nov 16, 2003 09:59 AM
8Grand
Jul 26, 2003 10:55 AM
vietgsrboi
Jul 16, 2003 03:46 AM
