GM Syncromesh users, a few questions!
Old Jun 18, 2003 | 08:04 PM
8Grand's Avatar
Default GM Syncromesh users, a few questions!
I put this syncromesh stuff in my DA9 about 2-3 weeks ago and Im not really noticing THAT much of a difference.....
Of coarse I had the o-so-common 3rd gear grind.....
I can shift at about 4500rms and not have the car grind(meaning the RPMS fall to like 3500 by time I get Into gear)
Anyone else notice a big difference when using this crap... or should I have saved my $$ and went with 90w redline? I mean I do notice some difference.... but it didnt totaly cure my 3rd gear scratch like everyone says it does(I know its my syncro so )
Should I just make the move to Redline in a couple thousand miles(I got say 1k with that fluid in there).... or does it take somemore time for this stuff work(I know it wont totaly cure my 3rd gear scratch)?????
Old Jun 18, 2003 | 08:15 PM
tegasaurus's Avatar
Default Re: GM Syncromesh users, a few questions! (CRX8Grand)
honda MTF cured my 3rd gear grind for me. but it was just in its beginning stages of scratching. everyone says GM synchromesh is jesus liquid, but i havn't found out what the big deal is?
-ryan
Old Jun 18, 2003 | 08:38 PM
jonsteR's Avatar
My 3rd gear started grinding after a track day on my 92 LS with 200k miles on the tranny. It would grind at any RPM but synchromesh cured that. I only grinded 3rd gear a few times at redline after putting synchromesh in.
Old Jun 19, 2003 | 12:45 AM
DesiDez's Avatar
r u sure u didn't put too much in?
Old Jun 19, 2003 | 06:00 AM
JBBNJ609's Avatar
Default Re: (FOBsquad)
wait , wait , if you put to much in it would make you grind?????? , please clarify and help
THANKS
JAY
Old Jun 19, 2003 | 06:04 AM
StyleTEG's Avatar
Default Re: (jason bouchard)
Its a great fluid, but its not going to fix major problems with your transmission. Its not going to repair your syncros.
Old Jun 19, 2003 | 07:54 AM
MugenGTR's Avatar
is this crap suppose to be used normally or just when you have problems?
Old Jun 19, 2003 | 11:05 AM
8Grand's Avatar
ahh well.... its done enough that it doesnt scratch during daily driving anymore... Im gonna hunt for another LS tranny and rebuild it soon....
Anyone know of any sort of syncros that are better then stock? LS trannies love to grind.
Old Jun 19, 2003 | 01:21 PM
ejprimo's Avatar
Default Re: (CRX8Grand)
heres a link to a used oil analysis of honda mtf:
http://theoildrop.server101.co...00562
Old Jun 24, 2003 | 07:41 PM
tegasaurus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX8Grand &raquo;</TD></TR><TR><TD CLASS="quote">LS trannies love to grind.</TD></TR></TABLE>
i was just thinking about this... Do LS trannies' 3rd gears grind more than, oh lets say a close gear ratio b16? i have some theories behind this...
-ryan
Old Jun 30, 2003 | 09:36 PM
8Grand's Avatar
Default Re: (tegasaurus)
well... after 2000 miles the fluid is starting to show signs of it working even better then when I posted this...
I can now shift at 5500rpms and not have this beotch grind... I didnt notice it till today really....
So this stuff gets a outa 5.... only because i cant shift at redline with it and have it cure my synco problem
I just think its due to a weak 3rd gear syncro.... LS's werent ment to take a beating like a GSR or b16 tranny is...
Old Jul 1, 2003 | 12:46 PM
VDo's Avatar
VDo
Just curious, which fluid did you use? The regular Synchromesh (#12345349) or the Synchromesh Friction Modifier (#12377916)? Just bought some of the second kind and will be putting it in this weekend. I have been using Redline MTL with good results, but wanna see what all the fuss is about.
Old Jul 1, 2003 | 05:17 PM
8Grand's Avatar
they just handed me the Syncomesh... they didnt ask about the friction modifier..... hrm... Im wondering if I just got the normal stuff. either way it worked damn well if it wasnt the Friction stuff.. I left the bottles at a friends garage and their probably tossed....
Chances are I got the Friction stuff... or at least I hope I didnt waste my 45$... they didnt ask if I wanted the friction mod stuff. I thought the Synchromesh **** came WITH the mod.
Old Jul 1, 2003 | 06:12 PM
VDo's Avatar
VDo
The friction modifier stuff comes in retangular containers and the regular stuff comes in round containers.
Old Jul 1, 2003 | 08:43 PM
MrSmith's Avatar
Default Re: (VDo)
what are the specific differences between the two?
Old Jul 1, 2003 | 08:57 PM
tilt's Avatar
Default Re: (MrSmith)
*edit*
I'm not sure about the two gm bottle differences but friction modifier is a good thing imo for lsd. Redline sells it too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrSmith &raquo;</TD></TR><TR><TD CLASS="quote">what are the specific differences between the two? </TD></TR></TABLE>
Modified by tilt at 12:10 AM 7/2/2003
Old Jul 1, 2003 | 09:20 PM
Mr. Softee's Avatar
Default Re: (tilt)
i run a honda mtf, motor oil, GM syncromesh mix. no grinds, EVER. GSR tranny.
Old Jul 2, 2003 | 10:25 AM
8Grand's Avatar
well ****, seems I got the regular stuff.. hell it worked DAMN well on my teg... no way Im flushing that **** out for the Friction Mod.. I wish I woulda known... I woulda just gotten 90w redline...
damn SM was 15.50 a quart!
Either way if the regular stuff worked this well I just wonder how well the mod stuff woulda worked.
Old Jul 25, 2003 | 11:45 PM
91HATCH's Avatar
Default Re: (8Grand)
are these gm syncromesh the same thickness as the honda mtf? or is it thicker? I have problems with shifting, mostly 5th, and was told that my clutch is causing that problem?
Old Jul 26, 2003 | 06:58 AM
au-gsr's Avatar
Default Re: (91HATCH)
90w redline???????? WTF?
you are nut the factory reccommends 5w30 mtf. any higher and you will grind your synchros to death. ask any honda/acura certified tech and they will tell you the same. i have used everything from redline to generic oil and so far honda mtf works the best.
Old Jul 26, 2003 | 07:55 AM
ltho1998's Avatar
Default Re: GM Syncromesh users, a few questions! (8Grand)
It synchromesh cured my 3rd gear grind. For being only 5 bucks a quart.. well worth the money, I haven't bitched about my tranny ever since i put that stuff in.
Old Jul 26, 2003 | 10:55 AM
The Rob's Avatar
I had a slight grind only at redline in my car. Used Honda MTL and it almost completely disappeared. Its time to change my fluid and I'm going with synchromesh this time to try it out.
Huberts5-lugBB1
Mar 18, 2018 04:22 PM
Kevykev
Acura TSX
Jul 13, 2008 09:33 AM
ekcoupe88
Honda Civic (2006 - 2015)
16
Apr 26, 2007 09:05 AM
bustedasscivic
Nov 16, 2003 09:59 AM
RTW DC2R
Sep 14, 2003 06:02 AM
