Help: Camber kit & upper control arm clearance
Hey guys,
My 93 Prelude was 3 deg off on camber after lowering it. The Camber kit installs easily enough, but now on the front wheels the upper control arm won't clear the fender/unibody seam. I could grind off the edge of the arm, but it won't gain enough space. Any ideas would be appreciated! BTW, the kit I have has the eccentric adjuster.
this is a common problem with camber kits for the lude. i'm assuming that this camber kit changes the mounting position of the A-Arm, and if you can't clear the top of the wheel well, well i'd say run a higher ride ht. until it does, or get yourself an SPC-style ball joint camber kit, and only beat the crap out of the top of the wheelwell occasionally.
it is my understanding that no one on this planet makes a decent camber kit for the lude. the thought of camber kits makes me angry. i'm gonna get a smoke.
azn_outlaw
Jan 19, 2002 05:03 AM
