Battery relocated.
Old Nov 17, 2003 | 05:28 AM
RAB's Avatar
RAB
Default Battery relocated.
Project went smooth.
Any questions?
Old Nov 17, 2003 | 06:00 AM
JohnnyTequila's Avatar
Default Re: Battery relocated. (RAB)
very nice, and clean.
im about to do this. i have that same battery box
how is the battery box being held down in the trunk??
and can you list all the parts you used,where you got them, size of wire, and where you grounded the battery in the trunk???
thanks a lot
nice DIY
EDIT: i own a 3rd gen prelude, and in order to put in my custom cold air i gota remove the battery, and relocate, what are your reasons for doing this??
Old Nov 17, 2003 | 06:39 AM
BolivianDc2's Avatar
Default Re: Battery relocated. (JohnnyTequila)
is that the summit battery box?
if so, did it come with absolutly everythign needed?
Old Nov 17, 2003 | 07:21 AM
RAB's Avatar
RAB
Default Re: Battery relocated. (Bolivianstrtwpn)
I got the summit racing kit. The box that is supplied with the kit is too large. I went to my local hardware store and got the box pictured.
-I used the existing stock battery tray and welded it to the sheet metal (not recommended as the sheet metal is very thin and if the welder it too hot you'll get holes.) I recommended bolting the tray down, I put a couple of bolts for added security.
-The cable supplied with the summit racing kit is heavy duty stuff, good wire.
-I used the existing stock tie down bar to essentially secure the battery to the tray and box.
All in all is more a custom job than anything else. As Corey says use your head and take your time.
Oh and I routed the cable throught the fire wall via the removal of the evaporator box, feed the cable throught the smaller of the two holes, then tied down the cable, then put the evaporator back in works perfectly.
Old Nov 17, 2003 | 08:13 AM
laughinxxx's Avatar
New User
So you ran the cable through the car? Is there any need to seperate the + and - wires or can they run next to each other?
Old Nov 17, 2003 | 08:55 AM
RAB's Avatar
RAB
Default Re: Battery relocated. (laughinxxx)
The negative (-) is grounded to the frame in the trunk not outside but inside its a really good ground.
Oh and the purpose of the project is to get weight off the nose of the car. Hopefully to make the Prelude Nationally STS competitive.
Modified by RAB at 11:11 AM 11/17/2003
Old Nov 17, 2003 | 09:55 AM
Kidd_Stylez's Avatar
what gage wire comes with the kit that connects to the battery?
Old Nov 17, 2003 | 02:07 PM
satan_srv's Avatar
Default Re: Battery relocated. (Kidd_Stylez)
I'm thinking you're gonna want my custom battery-relocated CF cold air intake I'm working on
Old Nov 17, 2003 | 02:11 PM
AndyD's Avatar
BEAUTIFUL MAN!!! I love seeing people mod their cars for a reason...RACING!!!
Thanks for the pics!!!
Old Nov 17, 2003 | 03:13 PM
fastludeh22's Avatar
Default Re: Battery relocated. (AndyD)
i did the same thing. i temp. have my battery in the same spot...question is, shouldn't we put it in the center of the trunk somewhere. i mean putting it in the back helps the 50/50 weight thing, but what about side to side?
now 2 things had me try it there first. 1. the driver is on the other side of the car, which should help even it out. and 2. it was on that side in the front from the factory. just wanted others opion's
Old Nov 17, 2003 | 03:16 PM
SUB-0 H23's Avatar
does this mod help for drag racing?
Old Nov 17, 2003 | 03:17 PM
skrewdlude's Avatar
Default Re: Battery relocated. (fastludeh22)
I would like input on this too, I have mine mounted in the middle of the trunk in the same box. Another point tho, I believe to be legal for racing. A relocated battety has to have
1. A sealed box with appropriate venting tubes.
2. A clearly marked electric cut out switch.
Just things I have read in some rule books.
This my not apply to windows down racing. Just things to think about
Josh
Old Nov 17, 2003 | 03:21 PM
flip1199's Avatar
Do u have a battery kill switch?
Old Nov 17, 2003 | 03:41 PM
Default Re: (flip1199)
ya you are supposed to have a kill switch outside the car. i dont understand why though. i mean whats the difference where the battery is, if the car need to be shut down
Old Nov 17, 2003 | 05:11 PM
KB96VTEC's Avatar
what I wanna know IS...can you feel any difference in weight transfer? does the car get up a little better say out of the 1st to 2nd shift?
Old Nov 17, 2003 | 05:29 PM
TimeRacer's Avatar
Why did you put it past the axle? I would of thought you'd want to install it in front or on the axle to have the weight in an easier place to rotate. I would of put it against the trunk wall as the main reason why you want to move the weight out of where it is originally is because it's so far past the front axle and not solely because it's in the front. Though that is an extra benifit!
Old Nov 17, 2003 | 08:46 PM
SUB-0 H23's Avatar
Default Re: Battery relocated. (satan_srv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv &raquo;</TD></TR><TR><TD CLASS="quote">I'm thinking you're gonna want my custom battery-relocated CF cold air intake I'm working on </TD></TR></TABLE>
have you dyno the cf intake already? how far long is it now?
Old Nov 17, 2003 | 09:54 PM
skrewdlude's Avatar
Default Re: Battery relocated. (TimeRacer)
mine is directly between the rear strut towers. I put it here for the reason you listed. I will take pics tomorrow if you guys want
Old Nov 17, 2003 | 10:56 PM
flip1199's Avatar
Default Re: (fastludeh22)
well if you don't have a kill switch, what's gonna shut off the power when u turn the car off??
Old Nov 17, 2003 | 11:29 PM
666's Avatar
666
Very niiice! Good Job
Old Nov 18, 2003 | 08:09 AM
Default Re: Battery relocated. (DoanTuTsMaiS00dA!)
The wieght of the driver offsets the wieght of the battery being located on the passenger side of the car
Old Nov 18, 2003 | 08:16 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flip1199 &raquo;</TD></TR><TR><TD CLASS="quote">well if you don't have a kill switch, what's gonna shut off the power when u turn the car off??</TD></TR></TABLE>
what turns off the power when its under the hood. it works exactly the same, no matter where the battery is.
Old Dec 2, 2003 | 11:32 AM
bassist2528's Avatar
I am going to build my own box for the battery, so what gauge wire should I run to the engine bay? Im thinking at least 4 gauge, but is that enough or should I go 2?
Old Dec 2, 2003 | 01:47 PM
h22turbolude's Avatar
hey i noticed it only has one fan. did you take out the ac? if so why?
Old Dec 2, 2003 | 01:54 PM
AndyD's Avatar
Default Re: Battery relocated. (h22turbolude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22turbolude &raquo;</TD></TR><TR><TD CLASS="quote">hey i noticed it only has one fan. did you take out the ac? if so why?</TD></TR></TABLE>
Yup, judging from the pics..he no longer has AC.
I bet it is because he autoXs his car.
