help, still confused on swap question
Old Nov 17, 2003 | 04:53 AM
endlesswinterco's Avatar
Default help, still confused on swap question
ok, after some research and some help here, im still a little fuzzy about my swap. im swaping in a b16a2 into a 94 eg hatch. i was told that the rear mount would work fine, but i need to order the other four mounts from an LS integra.
driver side rubber mount
driver side mount bracket
pass side upper mount
pass side mount bracket
please help me to understand better
Old Nov 17, 2003 | 05:56 AM
Default Re: help, still confused on swap question (RidinlowHatch)
up, need help today please
Old Nov 17, 2003 | 07:00 AM
up
Old Nov 17, 2003 | 08:04 AM
hybrid racing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RidinlowHatch &raquo;</TD></TR><TR><TD CLASS="quote">ok, after some research and some help here, im still a little fuzzy about my swap. im swaping in a b16a2 into a 94 eg hatch. i was told that the rear mount would work fine, but i need to order the other four mounts from an LS integra.
your stock mount will not work... you will need a mount from a 94 and up integra gsr/ls
e-mail me and i will send you pics of what you need...
will@hybrid-racing.com
Old Nov 17, 2003 | 09:08 AM
Default Re: help, still confused on swap question (6spdEG)
mail sent
Old Nov 17, 2003 | 09:48 AM
eyeamvic's Avatar
I was able to use all my old mounts for the swap, only thing I needed was the rear engine bracket which comes from any b-series engine. (I took mine from an LS). The driver side bracket should already be bolted onto the engine, if not, you're gonna need that one too.
Old Nov 17, 2003 | 10:10 AM
Revhard92si's Avatar
You need all the mounts from the integra 94up.
Old Nov 17, 2003 | 12:52 PM
cbaracing's Avatar
Default Re: help, still confused on swap question (eyeamvic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eyeamvic &raquo;</TD></TR><TR><TD CLASS="quote">I was able to use all my old mounts for the swap, only thing I needed was the rear engine bracket which comes from any b-series engine. (I took mine from an LS). The driver side bracket should already be bolted onto the engine, if not, you're gonna need that one too.</TD></TR></TABLE>
exactly.
Old Nov 17, 2003 | 01:50 PM
Default Re: help, still confused on swap question (cbaracing)
the motor i got dosn't have any mounts on it.
Old Nov 17, 2003 | 06:41 PM
VTECVillain's Avatar
Just to clear this up the MOUNT bolts to the rear cross member and is rubber in the center. You can use the stock Civic or an Integra MOUNT. But the mount BRACKET you will need a 94-01 Integra rear mount BRACKET.
Old Nov 17, 2003 | 06:51 PM
Default Re: help, still confused on swap question (VTECVillain)
This might also help, courtesy of Katman:
Old Nov 17, 2003 | 08:47 PM
thank you so much, that helps alot.
the soL that could
Aug 21, 2011 07:08 AM
mattltos
May 6, 2010 07:06 PM
ChinitodeNJ
11
Aug 10, 2009 01:45 PM
