Gauges to use with GSR swap
Old Nov 16, 2003 | 09:05 PM
eyeamvic's Avatar
Default Gauges to use with GSR swap
I have a del Sol Si but about a couple months back I threw in a b18c1. But then I was wondering what gauges I'd use for the swap. A while back I had bought sol VTEC gauges. The Si & VTEC redline is at the same spot on the tach. Since the VTEC gauges work on the b16a3, would it also be the same for the b18c1? I was wondering if maybe I hadn't taken my engine to it's full potential and been shifting at 7000 instead of the 8. Thanks in advance.
Old Nov 17, 2003 | 08:31 AM
eyeamvic's Avatar
Am I the only person with a swap done?
Old Nov 17, 2003 | 08:44 AM
wickedEFguy's Avatar
Default Re: Gauges to use with GSR swap (eyeamvic)
you should either get a JDM cluster like this
or I would check to see if you can find a EDM cluster that has MPH instead of KMH.
Old Nov 17, 2003 | 08:48 AM
Echo7847's Avatar
Default Re: Gauges to use with GSR swap (wicked B16)
The del sol Vtec gauge should redline around 81-8200rpm, which is the redline for the gsr motor also.
Old Nov 17, 2003 | 10:49 AM
Default Re: Gauges to use with GSR swap (Echo7847)
or you could find a USDM del sol cluster the had a B16 in it and just swap them out. check out Ebay
Old Nov 17, 2003 | 12:10 PM
eyeamvic's Avatar
Getting the gauge cluster would be the same as buying the gauges. The speedo is the same, just the RPM's is different. The location of the redline is in the exact same position. Just different number. I guess I'm gonna have to find the rev limit to see where it's at just to be sure. Or I can wait till I get the datalogging for the hondata and just read it from that. If anybody knows, it'd be helpful. If not, I'll get an update of my results.
ForgetMyNameX07
Nov 11, 2008 11:34 AM
DelSolMarine
Jul 26, 2006 02:23 PM
TurboJesse
Feb 16, 2003 03:20 PM
b18csol
Jul 19, 2002 06:12 PM
