What is a Stroker Kit?
Old Nov 16, 2003 | 07:37 PM
GSR x13's Avatar
Default What is a Stroker Kit?
What is a stroker kit? What does it do? does all the equipment in a stroker kit just go into the motor or does the motor need to be worked on?
Old Nov 16, 2003 | 07:47 PM
vteczone's Avatar
Default Re: What is a Stroker Kit? (Question)
stroker kits consist of all inside your bottom end but has longer stroke.most stroker kit just go in with no work done to the block but some might need boring or even resleeve.it increases your stroke and gain more power..thats what i understand .may be some one else can explain better.
Old Nov 16, 2003 | 08:07 PM
PhatOptimo's Avatar
Default Re: What is a Stroker Kit? (vteczone)
A motor can be stroked or de-stroked. Stroking ups the displacement. De-stroking lowers the displacement (smaller volume of cylinder). Different stroker kits require different things to be done to the block. Crowers B16 to 2.0L stoker kits say to remove the oil squirters because they get in the way. Also when stroking a motor the usual machine work has to be done like bore/hone the cyls., and deck the block. Usually stroking a motor throws the rod stroke ratio out the window at least it does on a B16 to 2.0L. De-stroking a B20 by using a B17 crank helps with the R/S ratio. A good R/S ratio keeps your rings any cyls in better condition if you want it to last a long time (street engine not race).
Old Nov 16, 2003 | 08:18 PM
GSR x13's Avatar
i have a GSR and if i stroke it with a "jun stroker kit" to go to 2.0L, would it be able to just go in or do i need the bore out the cyls and other misc stuff?
Old Nov 16, 2003 | 08:26 PM
PhatOptimo's Avatar
Default Re: (Question)
Jun Stroker kit specs:
B16B/B18C 82.0x94.0mm 1029M-H002 2.0L (Shaved Crankshaft)
I don't know if it needs to be bored. Probably will though.
Jun will have more tech info than I can provide.
I'm sure they will assemble you a shortblock for the right price.
Old Nov 16, 2003 | 10:14 PM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
Default Re: (PhatOptimo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhatOptimo &raquo;</TD></TR><TR><TD CLASS="quote">Jun Stroker kit specs:
looking at the specs 82.0 needs resleeving i wouldnt recommend boring to 82.0 mm from an 81mm stock sleeve.
jebintegra
Jan 25, 2006 07:10 PM
BOSS-REX
19
Oct 15, 2004 10:49 AM
VtecKiDD
Jan 12, 2004 07:47 PM
TypeRPaul
Jan 22, 2003 10:01 AM
90_Civic_Hatch
14
Dec 25, 2002 07:39 AM
