bearings needed for full bottom end rebuild???
Old Nov 16, 2003 | 07:08 PM
b16vtecsol's Avatar
Default bearings needed for full bottom end rebuild???
hey guys,
i just got a b18a1 block out of a 92' integra for $250 and I wanna replace all the bearings so it's like a new motor. I need to know what all i need beside the rod bearings. If someone could just give me a list of what i need that would be cool.
thanks
b
Old Nov 16, 2003 | 09:45 PM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: bearings needed for full bottom end rebuild??? (b16vtecsol)
Main, rod and thrust washers would be good. Just get the ACL kit for like $99.
Old Nov 16, 2003 | 10:45 PM
Suprdave's Avatar
Default Re: bearings needed for full bottom end rebuild??? (Mr Milano)
Measure before you drop ACLs in the motor...those bearings aren't always right...
If the motor doesn't want greens, or yellows...you dont wanna use ACL.
Suprdave
Old Nov 17, 2003 | 05:29 AM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: bearings needed for full bottom end rebuild??? (Suprdave)
I have had no problem with ACL's. As long as the crank is in good condition without any taper to it you will be within spec. Most ACL kits come with plasigauge so just measure. Regardless of what you use though I would ALWAYS measure. Even with the Honda color system, it may not always still be the same after prolonged use. If you use aftermakret rods etc... well you might as well forget it. As far as quality same as OEM honda. Both are tri-metal bearings, both install very easily. They aren't "better" then Honda and there not worse, but they are cheaper.
Old Nov 20, 2003 | 09:09 AM
luckypon7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Milano &raquo;</TD></TR><TR><TD CLASS="quote"> Just get the ACL kit for like $99.</TD></TR></TABLE>
where can you get those?
Old Nov 20, 2003 | 11:35 AM
zigs's Avatar
Default Re: bearings needed for full bottom end rebuild??? (luckypon7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by luckypon7 &raquo;</TD></TR><TR><TD CLASS="quote">
where can you get those?</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=631992
young-gun92eg
Feb 17, 2014 08:38 AM
X E Ryder
Jul 18, 2013 08:24 AM
Boostage
Oct 5, 2009 07:21 PM
importlegions
Oct 11, 2005 02:54 PM
rocket_R
May 13, 2005 09:19 AM
