pistons\rods for all motor+ N20
Old Nov 16, 2003 | 06:43 PM
BME1986's Avatar
Default pistons\rods for all motor+ N20
I am planning on going all motor. I have decide to go with a B18c1. I was going to go with CTR pistons but i also want to run between a 75-100 shot nitrous and I am worried that the CTR's wont be strong enough as I want this to be fairly reliable. What piston\rod setup would you suggest to get to about the same compression and be more durable?
Old Nov 16, 2003 | 06:57 PM
RS_H22's Avatar
Default Re: pistons\rods for all motor+ N20 (BME1986)
Your compression will be too high with CTR pistons for nitruous and that coupled with the fact that they are cast arent a good combo... Go with a set of forged pistons and rods... 11.0:1 is a good nitrous compression...
Old Nov 16, 2003 | 07:45 PM
Stunna BEN's Avatar
Don't call it a comeback
Default Re: pistons\rods for all motor+ N20 (RS_H22)
Some people like Total Seal rings as well. These may, or may not help, but an idea is always good
Old Nov 17, 2003 | 10:59 AM
BME1986's Avatar
Default Re: pistons\rods for all motor+ N20 (Stunna IDB)
What kind of whp should i be able to make with around 11.0:1, cams head work etc.?
Old Nov 17, 2003 | 12:38 PM
eyeamvic's Avatar
It depends what setup you decide to go with. What cams? You'd need more compression if you want to do some cams. Even for some CTR or ITR cams I would recommend around a 11.4:1 compression. Head work can help that engine breath, make sure it's done by a reputable place, personally I'd ship mine out and not have it done locally (then again nobody here does any head work for imports). It wouldn't be too hard to make 170-180whp with a decent setup on a GSR. CTR cams, i/h/e, cam gears, 11.4:1 CR, intake mani, and some tuning should do it. Similar to my setup, just need to do the pistons and I'm set.
Will_H
May 3, 2005 08:02 PM
2k1 GSR
Jan 18, 2005 05:13 AM
Mr HYDE
Mar 22, 2004 07:20 PM
akhom
Oct 13, 2002 07:58 PM
COREY ITR#625
Sep 30, 2001 01:45 PM
