H22A All-Motor Setups
For the all-motor ludes out there. What kind of setups are some of you running. I am hoping for some recomended parts. I was going to go all crower because I could get it at a good price. On the other hand, I have heard JUN parts perform exceptionally well.
i have an all jun set up, and your goal is more than accesible with this set up with the help of tuning and good performing bolt ons. good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectPenny »</TD></TR><TR><TD CLASS="quote">For the all-motor ludes out there. What kind of setups are some of you running. I am hoping for some recomended parts. I was going to go all crower because I could get it at a good price. On the other hand, I have heard JUN parts perform exceptionally well. </TD></TR></TABLE>
Depends on how much you want to spend and how much HP is your goal as well as realiability.
For a nice street motor, if you can get Crower stuff for a good price, then I would do the following:
Port and Polished Head
Crower Springs
Crower Retainers
Crower Camshafts
Crower Adjustable Cam Gears
Crower Stainless Steel Valves
Stock Type S Block
Thinner Head Gasket
The above setup should hit over 215WHP.
Now, if you wanna spend more money on a built block,
Crower Rods and Forged Pistons
Crower Springs
Crower Retainers
Crower Camshafts
Stock Type S Block
Thinner Head Gasket
Intake
AEM CAI 2.75"
K&N Cone Filter
64mm TB
IM ported to 64mm
Hondata IM Gasket
Fuel and Ignition
AEM FPR
RC 370cc injectors
TechTom P72 (like a hondata)
Apexi V-AFC
Head
H22A1 head ported by Top Power Racing , valve deshrouding blah blah
Crower Stage 3 cams
Skunk2 cam gears
Jun Valvesprings
Jun Titanium Retainers
Block
H22A4 Block
89mm LA sleeves
H22A4 stock crank balanced
Crower ProBillet H22A I-Beam Rods
ENDYN Rollerwave 11.89:1 pistons and rings
Stock Head Gasket bored to 89mm
Prodrive oil pump gears
Power Enterprise Super Strong Timing Belt
H23 manual tensioner
F20B Crank Pulley
Removed A/C
Exhaust
Trust/GReddy SS Header
Random Technologies High Flow Cat
GReddy Power Extreme 2.5" catback
Drivetrain
Clutchmasters Ultralight Flywheel
Clutchmasters stage 3 clutch
Accord Euro-R Transmission
AEM CAI 2.75"
K&N Cone Filter
64mm TB
IM ported to 64mm
Hondata IM Gasket
Fuel and Ignition
AEM FPR
RC 370cc injectors
Apexi V-AFC
Head
Crower Stage 3 cams
Skunk2 cam gears
Jun Valvesprings
Block
H22A4 Block
89mm LA sleeves
F20B Crank Pulley
Removed A/C
Exhaust
Drivetrain
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by All-Motor H22A »</TD></TR><TR><TD CLASS="quote">
Crower Springs
Crower Retainers
Crower Camshafts
Stock Type S Block
Thinner Head Gasket
Um no it won't. And you left out the cams, even with cams it won't get that much power
Crower Springs
Crower Retainers
Crower Camshafts
Stock Type S Block
Thinner Head Gasket
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kb58 »</TD></TR><TR><TD CLASS="quote">Though I tend to agree, he does indeed have "Crower Camshafts."</TD></TR></TABLE>
doh I can't read...he didn't specify the stage, at least give me that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv »</TD></TR><TR><TD CLASS="quote">btw I'll have a 'no balancer shafts' dyno test this week.
That's what you said last week.
The Lone Luder is the all motor H22A god!
here is a little info thing he put out a while ago
https://honda-tech.com/zerothread?id=180883
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22A EG6 »</TD></TR><TR><TD CLASS="quote">The Lone Luder is the all motor H22A god!
Nah, I just built, then broke and fixed more stuff than most people. It gave me experience.
Given money and opportunity again, I think that yes, I could build an N/A H22 that would be killer like my other one.
My pic for a good street/strip setup?
Full Portflow head with all the goodies
WebCam custom grind on fresh cam cores
Block bored and sleeved to 89mm
Arias pistons 12.5:1 cr (13.5+:1 if you want a track car)
Saenz rods
AEM EMS... Hondata if you're broke
Quiafe
HyTech or SMSP header
CAI
Walbro or Holly 342-347 fp
AEM FPR on an AEM fuel rail
440cc injectors
NGK plugs... given
open exhaust, 2.5. No cat, no muffler, no test pipe. Dump it out the side before the rear wheel.
UR cam sprockets
UR aluminum flywheel
UR pully set
ACT extreme PP and 6 puck disk
MSD 6A
10mm plug wires
and the usual random stuff. You get the picture.
With all of that together and broken in: DYNO DYNO DYNO
Then you'd have a car you'd be happy with...unless you wanted to pass an emissions test. I live in Alabama, I don't worry about that.
That's my humble opinion on a nice setup.
edit, forgot injectors
Saenz rods
Quiafe
CAI
440cc injectors
NGK plugs... given
UR cam sprockets
UR pully set
MSD 6A
10mm plug wires
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by biglew »</TD></TR><TR><TD CLASS="quote">12.5:1 on pump gas?</TD></TR></TABLE>
Tuning is your friend. Hence "DYNO DYNO DYNO." You MUST have access to 93-94 octane though.
Gotta live on the edge if you want to be faster than anyone else.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by biglew »</TD></TR><TR><TD CLASS="quote">Ugh, moving back to California soon premium is 91.</TD></TR></TABLE>
hahahahaha....
give up owning a fast car then. LOL The ****'s will deport you back to Chi-Town.
hahahahaha....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv »</TD></TR><TR><TD CLASS="quote">Intake
AEM CAI 2.75"
K&N Cone Filter
64mm TB
IM ported to 64mm
Hondata IM Gasket
Fuel and Ignition
AEM FPR
RC 370cc injectors
Apexi V-AFC
Head
Crower Stage 3 cams
Skunk2 cam gears
Jun Valvesprings
Block
H22A4 Block
89mm LA sleeves
F20B Crank Pulley
Removed A/C
Exhaust
Drivetrain
What is a Tom Tech p72... I know what a p72 is, but is Tom Tech some sort of program?
AEM CAI 2.75"
K&N Cone Filter
64mm TB
IM ported to 64mm
Hondata IM Gasket
Fuel and Ignition
AEM FPR
RC 370cc injectors
Apexi V-AFC
Head
Crower Stage 3 cams
Skunk2 cam gears
Jun Valvesprings
Block
H22A4 Block
89mm LA sleeves
F20B Crank Pulley
Removed A/C
Exhaust
Drivetrain
Monkey Fing a Coconut
Apr 21, 2004 01:57 PM
