fuel cell block off requirments for a civic h/b
The cell must be completely sealed with .028 inch Alluminum or .032 inch Sheetmetal. Must have sealed trap door. I have a fuel cell for sale if interested james..... Ron
before
after
before
after
thanx for the info who did the block off for ya and did you have to cut your floor?also let me know the specs on that fuel cell(aluminum?size?outlet sizes?etc)and ill take some measurements and get back to ya thanxs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22 civic »</TD></TR><TR><TD CLASS="quote">thanx for the info who did the block off for ya and did you have to cut your floor?also let me know the specs on that fuel cell(aluminum?size?outlet sizes?etc)and ill take some measurements and get back to ya thanxs</TD></TR></TABLE>
I only had to cut the floor a little underneath because i chose to run the lines under the car instead of out the rear wall and throiugh the rear bumper. Its a 5 gallon cell. the outles sizes are -10AN (x2). Ill have the exact measurements later for you later on.. Also, if you buy the fuel cell, ill give you this plate and brackets i made to seal it because i dont use tit anymore, its all yers man...
Does the fuel pump have to be level with the fuel tank.. Im assuming it does since the pumps are gravity fed.. If you ran the lines from under the car where did you mount your fuel pump at..
I bolted the fuel pump to the drivers side framerail. There was only a very slight incline from the cell to the pump. It worked fine on my car for 6 months until i removed it.
ChrisMillerRacing
Nov 21, 2011 08:11 AM
