transmission fill/drain plug...
i know this have been discussed before and i did search, but i dont see the picture in one of the post. i see three bolts with square reccess next to the axle. two to the right and one right below it. anyone got any pictures of it. its a 3/8 rachet, correct? thanks for any info
I think I put fluid in the one at the top right and drained it from the little one on the left. Do this. Undo the top right one. Look in the hole and see if fluid is right there. If it is fill it up by that one. If the fluid level is just below the bottom righthand bolt use that one. Then drain out the fluid via the left bolt and fill it back up via the prior verified right hand bolt to the original level.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by laughinxxx »</TD></TR><TR><TD CLASS="quote">I think I put fluid in the one at the top right and drained it from the little one on the left. </TD></TR></TABLE>
theres two bolt to the right, which one?
**Shakes head**
Ok, one more time. The fluid level rises up just below one of the bolts. I don't remember which, but I think that it is the top one. Undo the top bolt and see if the fluid level is just under that bolt. If it is, fill it back up by that bolt. If it isn't check the bottom right bolt to see where the fluid level is. Once you figure out where the fluid level is just fill it up until fluid pours out of the filler hole and screw the bolt back in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludeR917 »</TD></TR><TR><TD CLASS="quote">i got it now. sorry i didnt read your first post carefully. thanks. </TD></TR></TABLE>
cool.
cool.
ocdcivic
Dec 11, 2004 10:11 AM
Slammd Sol
Mar 28, 2004 10:21 AM
