what's involved with replacing pistons
Old Nov 16, 2003 | 01:02 AM
Wo-Nelly's Avatar
Default what's involved with replacing pistons
I was wondering if it is possible to replace pistons without pulling out the motor and if possible not pulling the head either. I was thinking of removing the oil pan, and going from there. I kinda want to do the least amount of work possible (cause I'm lazy, and the less I do the less chance of me doing something wrong) I just want to know if it is possible and has it been done
Thanks
Old Nov 16, 2003 | 02:21 PM
PrecisionH23a's Avatar
Default Re: what's involved with replacing pistons (GottaLude)
You have to pull your head in order to install the new pistons properly and remove the old ones. You can do so without pulling your motor, just be very careful when installing your new bearings.
Old Nov 16, 2003 | 02:52 PM
spoolinlude's Avatar
I live under a rock
Default Re: what's involved with replacing pistons (GudeH23a)
I think i'd be more work to do it w/o pulling the motor. If you did do it w/o pulling the motor, u'd need a lift to really be able to get under the car w/o doing any damage
4CDFED
May 7, 2007 04:53 PM
tempsohc
May 24, 2006 08:11 PM
the.hamburglar
Sep 30, 2005 07:07 AM
JDM_Spec
Dec 1, 2004 02:19 PM
