Installing Pistons
Old Dec 1, 2004 | 11:39 AM
JDM_Spec's Avatar
Default Installing Pistons
i thinking of buying some pistons, do you have to pull the motor out to change the rods and pistons, etc. or can you just work with the motor in the chasis but with the head off???
Old Dec 1, 2004 | 11:45 AM
opiumdaze's Avatar
either way its up to you. i prefer pulling it out and organizing the tools/bolts and nuts.
Old Dec 1, 2004 | 12:03 PM
Racermech's Avatar
Default Re: Installing Pistons (JDM_Spec)
You have to drop the oil pan also. I would say pull the motor, unless you like spending time on your back trying to work on the motor.....does not sound like a good time to me
Old Dec 1, 2004 | 02:19 PM
dick_213's Avatar
Default Re: Installing Pistons (Racermech)
it wouldnt be horribly bad to work with it in the engine. put the front end up on jack stands take off the oil pan. it would be best to put whatever rod journal at BDC so its easily accessible. then just run the pistons from the top of the head with a ring compressor and bolt the cap and bearing assembly from the bottom. u will spend some time on your back but it will end up being faster than taking out the engine. opium daze makes a good point about organizing the tools.
jyracer
Jan 13, 2009 08:16 PM
4CDFED
May 7, 2007 04:53 PM
the.hamburglar
Sep 30, 2005 07:07 AM
Wo-Nelly
Nov 16, 2003 02:52 PM
hatchback19
Mar 27, 2003 08:10 PM
