EG wiring Harness
Old Nov 15, 2003 | 10:10 PM
92CxHatchback's Avatar
Default EG wiring Harness
Witch 92-95 civic harness has a 4 wire o2 sensor. i just did an ls swap in my 92 cx, and i only have the cx harness (1 wire o2). i was told to get a newer civic harness with the 4 wire ot sensor. I heard the 95 CX has a 4 wire. Is that true? Thanx
Old Nov 15, 2003 | 10:20 PM
hybridnorth's Avatar
Default Re: EG wiring Harness (92CxHatchback)
get a 92-95 si harness, it has everythign you need
Old Nov 15, 2003 | 10:29 PM
Default Re: EG wiring Harness (hybridnorth)
is that the one you are using on your hatch?
Old Nov 15, 2003 | 10:44 PM
boostedcivicsir's Avatar
Mr. Badwrench
if you are doin an ls swap, you only need a dx harness. an si harness will command a little higher price as they are more sought after. but a dx harness will do you fine. if you get the si, it will allow you to do the vtec swap easier. thats all.
Old Nov 15, 2003 | 10:49 PM
Sasebonian's Avatar
the 92-95 ex/si will have it.
coupatroopa
Nov 2, 2010 06:26 PM
fhukingviet
Mar 8, 2009 07:50 AM
Mr. Roboto
Dec 18, 2007 05:45 AM
P_dizzle24
Jul 31, 2006 09:03 AM
KiNG $h!t
Aug 14, 2003 09:02 PM
