ECU codes 21,22 and 23 WHY?
Old Nov 15, 2003 | 09:20 PM
chero112's Avatar
Default ECU codes 21,22 and 23 WHY?
I recently did my vtec wiring and for about a whole day everything was fine. When I turned my car on today it started throwing codes andthe codes where 21,22 and 23. I check them and
21-vtec selnoid
22-vtec oil pre.
23-knock senor
Onec my car started throwing codes vtec didn't turn on anymore Why? WHat's the problem? And can I fix it my self?
Set Up 95 acura integra Ls with 2000 gsr with P72(obd1) ECU.
(NEED HELP)
Old Nov 16, 2003 | 08:13 PM
ProJectCvic's Avatar
Default Re: ECU codes 21,22 and 23 WHY? (chero112)
Why are you runnin an LS motor with a p72?
Old Nov 16, 2003 | 08:14 PM
mmuller's Avatar
Mad Scientist
Default Re: ECU codes 21,22 and 23 WHY? (ProJectCvic)
please tell me your kidding.................
Old Nov 16, 2003 | 08:15 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chero112 &raquo;</TD></TR><TR><TD CLASS="quote">I recently did my vtec wiring and for about a whole day everything was fine. When I turned my car on today it started throwing codes andthe codes where 21,22 and 23. I check them and
21-vtec selnoid
22-vtec oil pre.
23-knock senor
(NEED HELP) </TD></TR></TABLE>
It throwing code b/c the p72 is for a vtec motor, your ls motor do not have knock sensor, or vtec sol. That is why is it throwing a CEL. OR am i reading it wrong and you have a LS motor/ gsr head????
Old Nov 16, 2003 | 08:18 PM
pr0jektdc2's Avatar
21-vtec selnoid
22-vtec oil pre.
23-knock senor
Old Nov 16, 2003 | 08:50 PM
mmuller's Avatar
Mad Scientist
Default Re: ECU codes 21,22 and 23 WHY? (pr0jektdc2)
oh chit i was starting to freak out...
its probably a wiring problem, check your wiring.
katman's pic.
Old Nov 16, 2003 | 09:38 PM
chero112's Avatar
Default Re: ECU codes 21,22 and 23 WHY? (mmuller)
(Read set up guys) I running a 2000 GSR motor on my 95 LS, will I guessed it was the wiring also but vtec did work two days ago so I thought maybe a wire came loose or something like that so I check everything out made sure nothing came loose. All the wire were in place, every wire was tight and it still throwing codes.
can there be any other problems beside the wiring? Or should I just take it back to the place that did the wiring?
Old Nov 16, 2003 | 10:07 PM
mmuller's Avatar
Mad Scientist
yeah, take it back and let them fix it
Old Nov 18, 2003 | 03:57 PM
JeffNA's Avatar
Just sell your POS car!!!
Old Nov 18, 2003 | 05:14 PM
the buddha's Avatar
Default Re: ECU codes 21,22 and 23 WHY? (JeffNA)
i got the same prob but i did it myself but i got the gsr motor
tell me what happens but i think it might be the grounds
just keep trying
Old Nov 18, 2003 | 05:20 PM
integraL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JeffNA &raquo;</TD></TR><TR><TD CLASS="quote">Just sell your POS car!!! </TD></TR></TABLE>
LOL - he tries to ask for help, hoping for a solution to his problem...and he gets that....hahaha
dougk1401
Dec 7, 2009 08:55 AM
EGThang
18
Jun 6, 2008 03:26 PM
silverboost
10
Aug 28, 2006 09:21 PM
Attoir
Jan 10, 2006 06:45 PM
Luserkid
18
Mar 8, 2004 07:24 PM
