vafc question for nissan
Old Nov 15, 2003 | 04:35 PM
fastintegra's Avatar
Default vafc question for nissan
will a apexi vafc work in a nissan sentra 2.5 ser specv.
Old Nov 15, 2003 | 04:39 PM
Loccster's Avatar
Default Re: vafc question for nissan (fastintegra)
nope, but s-afc will....
Old Nov 15, 2003 | 04:45 PM
why wouldnt it work its got nissans version of vtec.
Old Nov 15, 2003 | 06:34 PM
neo1z's Avatar
Default Re: (fastintegra)
VAFC - VTEC Air Flow Converter.
Notice - VTEC. As in - Made for Honda/Acura.
Yes - you can use the VAFC on the Nissan - but only for fuel stuff. Itll be just like an SAFC. You cannot control Nissan's variable valve timing with a VAFC.
Old Nov 15, 2003 | 07:03 PM
IN VTEC's Avatar
Default Re: (neo1z)
Aside from the VTEC thingy....
Nissan's use a hot-wire MAF to measure to determine mass air. Honda's use a MAP sensor to calculate mass air.
Granted that both use a 0-5V sensor input voltage range, I don't believe they can be used interchangeably b/c of the translation of the input voltage on the sensor end. I'm not really sure how to explain it. It's just different....there, that ties things up nicely. Maybe Jim Blake can explain.
Old Nov 15, 2003 | 07:58 PM
neo1z's Avatar
Default Re: (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">Aside from the VTEC thingy....
Granted that both use a 0-5V sensor input voltage range, I don't believe they can be used interchangeably b/c of the translation of the input voltage on the sensor end. I'm not really sure how to explain it. It's just different....there, that ties things up nicely. Maybe Jim Blake can explain.</TD></TR></TABLE>
Listen to him. He knows alot more than me.
So we are saying that even an SAFC will not work on a Nissan or...?
Old Nov 15, 2003 | 08:03 PM
theSYNDICATE's Avatar
From: Derek Jeter drinks wine coolers,, The Nation, USA
Default Re: (neo1z)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neo1z &raquo;</TD></TR><TR><TD CLASS="quote">VAFC - VTEC Air Flow Converter.
I thought it wa controller?
Old Nov 15, 2003 | 08:34 PM
IN VTEC's Avatar
Default Re: (neo1z)
So we are saying that even an SAFC will not work on a Nissan or...?</TD></TR></TABLE>
No. Just the VAFC's. The VAFC only works with MAP sensor-based engine management systems.
The SAFC has a user-definable sensor type (eg: Karman Vortex, Hot-wire, or MAP) so that you can use it on any sensor type. You have to know what type of sensor the system uses to determine engine load before you can select. The SAFC manual has charts to help you with that, but the general rule of thumb is that DSM's always use Karman Vortex, Nissan's use Hot-wire MAF, and Honda's use MAP. I'm not sure what kind of MAF Toyota uses, but their turbo cars utilize both MAP and a MAF.
Old Nov 15, 2003 | 09:00 PM
neo1z's Avatar
&lt;----- Own3d.
Well...I guess I was half right. I did say the VAFC wouldnt control the Nissan's variable valve timing.
Old Nov 17, 2003 | 08:43 PM
oh well its not for me any way its for a friend.does any one offer anything that controls the spev.ive never been in the car but the way he explains it to me it sounds like a vtec he says after certain rpm sound and power change like in my b16.so my question is again does any one offer anything that controls the engagement point of what ever his car has is called?
Old Nov 17, 2003 | 08:56 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastintegra &raquo;</TD></TR><TR><TD CLASS="quote">oh well its not for me any way its for a friend.does any one offer anything that controls the spev.ive never been in the car but the way he explains it to me it sounds like a vtec he says after certain rpm sound and power change like in my b16.so my question is again does any one offer anything that controls the engagement point of what ever his car has is called?</TD></TR></TABLE>
im going to say no.
Old Nov 17, 2003 | 09:42 PM
neo1z's Avatar
Default Re: (dLo GSR)
Isnt the Spec V's variable valve timing on-going - like I-VTEC?
Old Nov 26, 2003 | 12:51 PM
QUiKSR20's Avatar
The QR25DE Has variable timing. Its not CAM Switching like in a VTEC.. Nissans VVL Motors from JAPAN like the SR20VE have a VTEC Like CAM PROFILE Switching
mechanism. A VAFC would work with NEOVVL Motors but not the Spec V. The spec V's is nothing special.
Old Nov 29, 2003 | 09:12 AM
brucek2's Avatar
The "changeover" you hear is the secondary intake runners opening up. CVTC is continous, its not like vtec. go to b15sentra.net and search for secondary intake runners and you will find tons of information.
teggyturboLS11420
Dec 8, 2003 08:56 PM
10seconds
Jul 8, 2002 01:34 PM
SuperRice
Apr 29, 2002 04:37 PM
BoroDB8
Apr 25, 2002 05:20 AM
