Jerky, stagnate acceleration...
Sushi Buffet Champion
I have a B20vtec, when I accelerate almost half the time it jerks or is stagnate (barely pulls). Also jerks when shifting, it's hard to do a smooth shift.
Funds were low after the swap, so it's still running on old/used B20 spark wires and plugs. The distributor is from a 99 Si and rotor hasn't been changed. Still
running on the B20 injectors.
ECU is P73, fuel pump is 99 Si. Running on a stock exhaust system.
Please help. TIA.
Please help. TIA.
has it ever thrown a cel? if so, check that, and either way, try replacing the fuel filter, they're like $10, so even if that ends up not being the problem, you didn't really waste any money
No, it doesn't throw a cel. I was hoping it'll be fuel delivery or spark management. But some said the B20 block and the vtec head throws off the oil pump sensor causing the jerkiness and I would need to switch to the P28 ecu. Any thoughts?
jerrys7583
Mar 23, 2011 12:59 AM
