External coil?
Old Nov 15, 2003 | 02:24 PM
chrisir19's Avatar
Default External coil?
Ok my 98 ITR dist. just **** it's coil and I am about to grab some advance auto parts store crap coil but then i was thinking ...can i not just run the + and - wires out to a high voltage/ better sparking external coila nd add the modified coil cap tip and wire...??? need to know asap please
and yeah i already searched!
Bump...TTT
Modified by chrisir19 at 2:00 AM 11/16/2003
Old Nov 16, 2003 | 07:48 AM
chrisir19's Avatar
Default Re: External coil? (chrisir19)
bump!
Old Nov 16, 2003 | 07:58 AM
sledgehammer's Avatar
Yeah you can do that. Just go out and buy the MSD Blaster Coil and Modified Distributor Cap. It's a very easy install. But just an FYI you don't need to get that MSD stuff, stock honda ignitions are very good and will most likely suffice for your setup.
Mike
Old Nov 16, 2003 | 12:04 PM
chrisir19's Avatar
Default Re: External coil? (sledgehammer)
"i was wondering cause it's time for a new coil and what a time to step it up and get a performance part, and maybe make the car alittle faster. Woud the coil help with a fuller spark??? bump for some more info
Old Nov 22, 2003 | 11:56 AM
chrisir19's Avatar
bump... how the hell do you fix a damn dist that is thworing a CYP code .This is very important cause it is messing up too cars at the moment..... HELP!!!
kadidle
Jan 3, 2009 07:39 AM
honda_SiRII94
Apr 9, 2007 08:14 AM
Jonny Rocket
18
Jan 11, 2007 02:37 PM
SpoolnByYou
Mar 25, 2006 09:10 AM
pornstarSR
Apr 26, 2004 04:05 PM
