headlights dim
hey guys please help got a huge issue i'm recently installed my jdm headlights on my 93 teg and theirs a short somewhere in the system when i turn on my headlights the right turn signal in the gauge cluster is slightly dim and the headlight blinks to the turn signals when i signal right and it's also affecting my heating system as to when i turn on the fan it's barely blowing but when i turn off the headlights it starts to blow harder then when i shut off the car it blows at max please help anyone
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ohhenrygs »</TD></TR><TR><TD CLASS="quote">hey guys please help got a huge issue i'm recently installed my jdm headlights on my 93 teg and theirs a short somewhere in the system when i turn on my headlights the right turn signal in the gauge cluster is slightly dim and the headlight blinks to the turn signals when i signal right and it's also affecting my heating system as to when i turn on the fan it's barely blowing but when i turn off the headlights it starts to blow harder then when i shut off the car it blows at max please help anyone
Hmm...Check if you have all your grounds connected. Usually things like that happen if you don't ground your wires correctly. Good luck.
Cheers
</TD></TR></TABLE>Hmm...Check if you have all your grounds connected. Usually things like that happen if you don't ground your wires correctly. Good luck.
Cheers
hey thanxs man i've also forgot to mention that i also pulled out my a/c compressor so that means that the wiring harness for compressor and condensor fan is just hanging their it looks like it's got 2 relays, 2 ground wires and one Red wire witch i think it's positive for the compressor i dunno if this might be my problem but i tried to ground the black wires and still no luck man this is bugging me so much any more solutions??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ohhenrygs »</TD></TR><TR><TD CLASS="quote">hey thanxs man i've also forgot to mention that i also pulled out my a/c compressor so that means that the wiring harness for compressor and condensor fan is just hanging their it looks like it's got 2 relays, 2 ground wires and one Red wire witch i think it's positive for the compressor i dunno if this might be my problem but i tried to ground the black wires and still no luck man this is bugging me so much any more solutions??</TD></TR></TABLE>
There's your problem...
the relays should be grounded to the chasis anywhere should be fine as long as it's on the chasis and convenient for you to take out if something goes wrong with it in the future.
oh man i hope this works man i lovin this place you really are a JDM_Honda_Fiend
i'll keep you updated umm how about the red wire coming from the harness on the a/c ?? i've got 2 black wires, one red wire and what looks like 2 relays plus the two plugs for the condensor fan
