headlights dim
Old Nov 15, 2003 | 02:19 PM
ohhenrygs's Avatar
Default headlights dim
hey guys please help got a huge issue i'm recently installed my jdm headlights on my 93 teg and theirs a short somewhere in the system when i turn on my headlights the right turn signal in the gauge cluster is slightly dim and the headlight blinks to the turn signals when i signal right and it's also affecting my heating system as to when i turn on the fan it's barely blowing but when i turn off the headlights it starts to blow harder then when i shut off the car it blows at max please help anyone
Old Nov 15, 2003 | 02:22 PM
JDM_Honda_Fiend's Avatar
Default Re: headlights dim (ohhenrygs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ohhenrygs &raquo;</TD></TR><TR><TD CLASS="quote">hey guys please help got a huge issue i'm recently installed my jdm headlights on my 93 teg and theirs a short somewhere in the system when i turn on my headlights the right turn signal in the gauge cluster is slightly dim and the headlight blinks to the turn signals when i signal right and it's also affecting my heating system as to when i turn on the fan it's barely blowing but when i turn off the headlights it starts to blow harder then when i shut off the car it blows at max please help anyone </TD></TR></TABLE>
Hmm...Check if you have all your grounds connected. Usually things like that happen if you don't ground your wires correctly. Good luck.
Cheers
Old Nov 15, 2003 | 04:48 PM
ohhenrygs's Avatar
Default Re: headlights dim (JDM_Honda_Fiend)
hey thanxs man i've also forgot to mention that i also pulled out my a/c compressor so that means that the wiring harness for compressor and condensor fan is just hanging their it looks like it's got 2 relays, 2 ground wires and one Red wire witch i think it's positive for the compressor i dunno if this might be my problem but i tried to ground the black wires and still no luck man this is bugging me so much any more solutions??
Old Nov 15, 2003 | 04:56 PM
neo1z's Avatar
As for the dimness....
Lens could be dirty...look at it and see if its all hazy. If so you need to do some cooking
Old Nov 16, 2003 | 05:37 AM
ohhenrygs's Avatar
Default Re: headlights dim (neo1z)
naw man i know it's just gotta be in the wiring just a matter of locating it. I'm pretty sure it's gotta be a ground but just where
Old Nov 16, 2003 | 05:40 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ohhenrygs &raquo;</TD></TR><TR><TD CLASS="quote">hey thanxs man i've also forgot to mention that i also pulled out my a/c compressor so that means that the wiring harness for compressor and condensor fan is just hanging their it looks like it's got 2 relays, 2 ground wires and one Red wire witch i think it's positive for the compressor i dunno if this might be my problem but i tried to ground the black wires and still no luck man this is bugging me so much any more solutions??</TD></TR></TABLE>
There's your problem... the relays should be grounded to the chasis anywhere should be fine as long as it's on the chasis and convenient for you to take out if something goes wrong with it in the future.
Old Nov 16, 2003 | 12:35 PM
ohhenrygs's Avatar
oh man i hope this works man i lovin this place you really are a JDM_Honda_Fiend
i'll keep you updated umm how about the red wire coming from the harness on the a/c ?? i've got 2 black wires, one red wire and what looks like 2 relays plus the two plugs for the condensor fan
Old Nov 16, 2003 | 09:24 PM
LBR92DA-T's Avatar
wanna sell your headlights? ... just curious.. i need a set.. looking for a set for cheap.. thanks! free bump
Old Nov 17, 2003 | 09:19 AM
ohhenrygs's Avatar
Default Re: (LBR92DA-T)
well i live in Ontario Canada the shippin might be crazy man
Old Nov 17, 2003 | 11:56 AM
LBR92DA-T's Avatar
post some pics of them.. give me a price and i'll see whats up...
propwdialogue
Jan 21, 2008 12:15 PM
1991 DA
Aug 13, 2006 09:16 PM
sicx
Jul 10, 2004 01:35 PM
