98 jdm itr into a 92 cx...?
Old Nov 15, 2003 | 09:02 AM
FBPninetynineEM1's Avatar
Default 98 jdm itr into a 92 cx...?
finally got the car running decent and im throwing codes 1 and 14...
1- o2 sensor
14- IACvalve
i used the stock 92 cx harness for the swap and just extended the o2 sensor wire so its currently a one wire o2 sensor...ive been told i have to use a 4 wire o2 sensor to not throw a o2 code...
does anyone have PINOUTS for a OBD-1 P30 B16 ecu...????
and does anyone have any recomendations on what to do about the IACvalve???...
the motor only has 30k miles so im i dont see how it could have gone bad already and ive tried cleaning it out and stuff.....thanx for all the help!
Old Nov 15, 2003 | 09:05 AM
pennies_hatchie's Avatar
Default Re: 98 jdm itr into a 92 cx...? (TDReh2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TDReh2 &raquo;</TD></TR><TR><TD CLASS="quote">finally got the car running decent and im throwing codes 1 and 14...
1- o2 sensor
14- IACvalve
the motor only has 30k miles so im i dont see how it could have gone bad already and ive tried cleaning it out and stuff.....thanx for all the help!</TD></TR></TABLE>
check to see if the iacv was plugged in, also you might want to solder your O2 sensor for better connection.
Old Nov 15, 2003 | 09:12 AM
Default Re: 98 jdm itr into a 92 cx...? (pennies_hatchie)
both have been...but thanks for the seuggestions
Old Nov 15, 2003 | 12:54 PM
anything else...i still need those pinout digrams
Old Nov 16, 2003 | 05:17 AM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TDReh2 &raquo;</TD></TR><TR><TD CLASS="quote">i used the stock 92 cx harness for the swap and just extended the o2 sensor wire so its currently a one wire o2 sensor...ive been told i have to use a 4 wire o2 sensor to not throw a o2 code...</TD></TR></TABLE>
Actually you MUST use a 4 wure O2 and wire it up properly. The CX uses a 1 wire O2 which will not work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">does anyone have PINOUTS for a OBD-1 P30 B16 ecu...????</TD></TR></TABLE>
OBD1 P30 ECU Pinouts
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">and does anyone have any recomendations on what to do about the IACvalve???...</TD></TR></TABLE>
First check and make sure that the IACV plug from your engine harness is clipped in good or if it's even the right one. There a few 2 prong plugs in that location that would plug in but end up not being the right one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">the motor only has 30k miles so im i dont see how it could have gone bad already</TD></TR></TABLE>
Doesn't all JDM motors?
Old Nov 16, 2003 | 08:25 AM
Slopoke's Avatar
Default Re: 98 jdm itr into a 92 cx...? (VTECVillain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain &raquo;</TD></TR><TR><TD CLASS="quote"> Doesn't all JDM motors? </TD></TR></TABLE>
Ha ha
Old Nov 16, 2003 | 10:35 PM
Default Re: 98 jdm itr into a 92 cx...? (Slopoke)
vtec villian...thanx for the pin out sheet...now does any one know where i can find a how-to on how to do convert from 1 wire to 4 wire o2 sensor...?
Old Nov 17, 2003 | 04:25 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TDReh2 &raquo;</TD></TR><TR><TD CLASS="quote">now does any one know where i can find a how-to on how to do convert from 1 wire to 4 wire o2 sensor...?</TD></TR></TABLE>
Search on here and you'll find a post that I and a few other contributed to, which tells exactly how to rewire to a 4 wire O2.
Drama13
Dec 28, 2012 05:47 PM
z6htch
Nov 18, 2009 05:16 PM
Markb16a
Dec 2, 2006 05:40 PM
Wazup
Jun 4, 2006 02:42 AM
5STAR3
Aug 31, 2003 09:42 AM
