Shock/Spring install
Old Nov 15, 2003 | 08:30 AM
Project99EK's Avatar
Default Shock/Spring install
after you install shocks and springs in your car by yourself, do you need to get your wheels aligned? someone told me i did.
Old Nov 15, 2003 | 08:51 AM
97civicdx's Avatar
Default Re: Shock/Spring install (Project99EK)
only toe angle can be adjusted, unless u get a camber kit. Also depends on your drop.
Old Nov 15, 2003 | 08:55 AM
Tanmt's Avatar
get a camber kit.. then get an alignment.. it'll save your tread, better braking, and handling..
Old Nov 15, 2003 | 08:57 AM
uranazo's Avatar
Default Re: Shock/Spring install (97civicdx)
YES!! everytime you drop the car you have to align the camber, do it or you will regret it later, i know i did... but yes you have to realign the toe after installing new springs/struts ... i just did mine last night, toe was off by 1 or 2 degrees...
accord4door
May 24, 2006 01:53 AM
Kronn 98SH
Suspension & Brakes
Jun 21, 2005 06:08 AM
kip0485
Suspension & Brakes
Mar 21, 2005 01:59 PM
Elemental
Sep 21, 2004 10:35 AM
