throttle cable install
Old Nov 15, 2003 | 07:28 AM
AWDxBOOST's Avatar
Default throttle cable install
i have an oem itr throttle cable to put on, but ive never installed one nor seen it done....
am i just better off going to a shop to get it put in?
Old Nov 15, 2003 | 07:32 AM
slammed_93_hatch's Avatar
Default Re: throttle cable install (ls_teg)
no its easy to do,... well i take that back its a bitch but not "hard" on a difficult level. disconect ur old one at the mani. then get in ur car with a flashlight look at it take it apart and the pull it out threw the engine bay then feed the new one threw and hook it back up.
i know this isn't very explicet, but its self explanatory, give it a shot
Old Nov 15, 2003 | 07:37 AM
AWDxBOOST's Avatar
Default Re: throttle cable install (slammed_93_hatch)
hmmm...seems like id rather not 'give it a shot' and mess up this motor...
well i guess to a shop it is! thanks
Old Nov 15, 2003 | 09:22 AM
dwnthehatch's Avatar
It takes 5 mins. Disconnect the cable from your throttle body and gas pedal assembly. Twist the white plastic part that is attached to your firewall. Pull the cable out through your engine comparyment. Reverse the procedures to install.
B16-CRX
Apr 12, 2009 05:36 PM
DeKaP
Aug 31, 2004 06:23 PM
rockwilda
Aug 25, 2002 08:32 PM
ic108
Dec 5, 2001 11:10 PM
