whats the difference between peak and hold vs saturated injectors from RC
lookin at getting 310cc injectors from rc but what is the difference in peak and hold vs saturated...what would be best for an all motor setup that has rebuilt bottom end and headwork
OBDI are peak and hold
OBDII are saturated
or i may have them switched
also if u gonna be pushing over 200hp u really dont need bigger injectors
just get a adj FPR; so ive been told
OBDII are saturated
well my friend has over 200hp and he has 270cc injectors and a fuel pressure regulator and his injectors are at max flowing load...he cant get anymore out of them...we have similar setups and i dont want to go through with this...
anyone know which it is above...i have an obd 1 setup so which injector should i get
Guest
Posts: n/a
OBDII are saturated
OBDII are saturated
It all depends on the year of the car. OBD1 and OBD2 engines could be either.
Go see www.rceng.com they have a fuel calculator on the site that can help you to determine what you need.
well i figured out what size i need, now what type...peak and hold or saturated...whats the difference between the 2 types
I how have 440cc/min injectors
