How do you raise your idle (idle issues)
Old Nov 14, 2003 | 08:38 PM
Boost2NA's Avatar
Default How do you raise your idle (idle issues)
Im running a LS-VTEC turbo set up. Im using a clutchmasters 8 lb flywheel with MSD 720cc injectors. All fuel management is controlled via hondata. The car has been through several different tuners (shad of abacus racing in va beach and tony 1 who use to work at Jotech). Noone has been able to make the car idle at all. The last tuner who messed with it was Tony and he said it was due to the flhywheel being so light.
Tony ended up adjusting a screw on the throttle body to let air bybass the butterfly valve at idle. It still does not idle but instead of idling the revs fluctuate up and down from 800-1500. This is starting to get annoyijng. If I set the screw back to stock the car will stall when i push the clutch in.
My question is how do I make my car idle at lets say 1200 or so. Can I physically do it myself, do do I have to take my car somewhere, or can I send someone one of my chips and they can do it for me. It just gets annoying when im at stop lights and the car is fluctuating between 800-1500 constantly (especially since im running open DP) Thanks guys any help will be appreciated
Old Nov 14, 2003 | 08:59 PM
B18PoweredCivic's Avatar
Try adjusting the cable a little bit...tighten it up...and adjust the screw on the throttle body accordingly..
Old Nov 14, 2003 | 09:34 PM
Boost2NA's Avatar
Default Re: (B18PoweredCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18PoweredCivic &raquo;</TD></TR><TR><TD CLASS="quote">Try adjusting the cable a little bit...tighten it up...and adjust the screw on the throttle body accordingly..</TD></TR></TABLE>
ill give this a shot but isnt there any way u can raise it through the hondata. Like if I sent someone one of my chips couldnt they change it on there
Old Nov 15, 2003 | 08:57 AM
Boost2NA's Avatar
Default Re: How do you raise your idle (Boosted99Si)
back to the top
Old Nov 15, 2003 | 02:22 PM
Jimmy's Avatar
Global Moderator
I dunno man...but uhh BuMp f0R j0o! ttt
Old Nov 15, 2003 | 03:44 PM
aeolus's Avatar
Default Re: How do you raise your idle (USDMDC2)
just turn the idle screw out 'til your satisfied with the idle or see if you can unplug a sensor that you dont need from the intake manifold to get some extra air in.If it idles up and dowm,you may have to adjust the tps...And sometimes,my idle will want to die when i have the revs up high for a while then all of a sudden i press in the clutch....might be cuz of my aluminum flywheel too.Do you have any check engine codes???
Old Nov 15, 2003 | 11:36 PM
Boost2NA's Avatar
Default Re: How do you raise your idle (aeolus)
No check engine lights at all. Just the car once warmed up constantly jumps up and down. Where is the TPS sensor located and how do I adjust it. Thanks for your help.
ciiivic89
Feb 9, 2009 07:03 PM
skata89
Jun 3, 2006 12:58 PM
turboB16RFD
Oct 9, 2005 09:15 PM
99b18
Nov 11, 2004 05:36 AM
