AEM Install
Old Sep 11, 2001 | 12:33 AM
5-SpeedFreak's Avatar
New User
Default AEM Install
I just recieved an AEM CAI for my 2001 Integra GS-R
It's nighttime, and I'm wanting to have a smooth install tomorrow.
Any helpful hints? The instruction manual (if you want to call it that) seems kinda confusing. What are the 2 hoses for?
I also purchased the bypass valve. Should I even bother installing that?
Thanks!
M.W.
Brand-New 2001 GS-R.
It's a virgin that's ready to SCREAM!
Old Sep 11, 2001 | 03:21 AM
yaksplat's Avatar
Default Re: AEM Install (passion4healing)
dont bother with the bypass
why would you want to cut such a nice pipe?
Old Sep 11, 2001 | 04:17 AM
Ubermensch's Avatar
Hoses: one runs from the valve cover to the AEM piping, the other replaces a coolant line from the throttle body to the block.
Hint: Be prepared to get pissed at how difficult it is to remove the coolant hose.
Old Sep 11, 2001 | 07:25 AM
pstreck's Avatar
New User
Default Re: AEM Install (Ubermensch)
The coolant hose can be a bitch.. its a pretty easy install though. Make sure to take off your front passenger wheel, or you wont be able to get the stock air box out. I wouldnt bother with the bypass valve its a pos. I've driven in crazy rain with aem cai without any problems. Just take your time its an easy install.
Old Sep 11, 2001 | 08:11 AM
Scary1109's Avatar
I completely agree, i riped the hose to shreds after i got it out....it didn't help with the install (which isn't that bad) but i sure did feel better about that small rubber hose then
Old Sep 11, 2001 | 09:15 AM
Rory Breaker's Avatar
Default Re: AEM Install (Scary1109)
Id install the bypass valve...you have it, why not install it. Just use the template and slice the pipe...voila.
You dont have to remove the wheel...just turn it all the way to the side.
Old Sep 11, 2001 | 09:19 AM
H23 Power's Avatar
Default Re: AEM Install (newgsrdriver)
you dont need those hoses, i took one, cut it, placed it inbetween the intake and the metal pipe from the valve cover...thats all that needs to be done...AEM is not very smart or economical with their parts
[Modified by 01GSR, 12:19 PM 9/11/2001]
Old Sep 11, 2001 | 10:36 AM
IgniteTeg's Avatar
Default Re: AEM Install (01GSR)
Thats what I did why bother with the coolant hose.
[Modified by IgniteTeg, 11:36 AM 9/11/2001]
Old Sep 12, 2001 | 01:18 AM
New User
The install went very easily!
I did install the bypass valve. The decision to do so made the installation much easier. I was able to install it in 2 pieces. It would have been a PAIN in the A-- to get it under the upper strut tower.
On a different note... The installation of the CAI gave me some respite from todays events.
To all those of you out there, G-D bless you all.
--M.W.
Old Sep 12, 2001 | 04:21 AM
pstreck's Avatar
New User
hehe, you gota take off the upper strut tower bar! its 4 bolts
Old Sep 12, 2001 | 12:12 PM
New User
Default Re: AEM Install (pstreck)
I thought about taking off the strut tower, but I figured that I didn't have to do that with the 2 pieces of piping ;-)
My car has noticably better top end, especially in 3rd gear when it's taching out at around 5000-7500 rpm...
The intake is also louder than the original, which makes it easier to hear the engine when heel-toe shifting.
Thanks for all your hints.
Next project: DC Headers and GReddy Exhaust.
M.W.
2001 GSR
The Virgins screaming louder now!
Old Sep 12, 2001 | 12:42 PM
N4Speed07's Avatar
New User
can someone please describe to me what heal toe shifting is, i hear it a lot and never learned what it was, thanks
niteboyzzz
Jun 4, 2003 03:45 PM
bad93ex
Dec 28, 2002 09:28 AM
GSRacer2102
Jan 5, 2002 09:55 AM
ITR #1202
Oct 15, 2001 06:27 AM
Isaac
Jun 27, 2001 08:55 AM
