Flywheels: Aluminum or Chromoly
Old Nov 14, 2003 | 03:54 PM
hiendgsr's Avatar
Default Flywheels: Aluminum or Chromoly
Ok, need you're experiences with either one. In talking with ACT and Fidanza I get differing opinions and theories.
Old Nov 14, 2003 | 05:07 PM
Jaesung's Avatar
have act stage 3 clutch with 9lb aasco similar to fidanza flywheel. so far i love it. it is unsprung and got it from heeltoeauto Marcus. great service. try sprung next time.
Old Nov 14, 2003 | 07:23 PM
hybridcrx's Avatar
Default Re: (Jaesung)
um...I had an exedy chromoly for about a year. Never had a problem, and it wasn't sprung (didn't even know they made sprung flywheels.....hmmmmm.) I think it was 10 1/2 lbs? Can't really remember. I just got it for piece of mind about aluminum wheels shattering. Don't think I really ever hear it happening....but flywheel chunks through my car and maybe in my passengers ***** didn't sound like fun.
Old Nov 14, 2003 | 07:39 PM
sledgehammer's Avatar
Default Re: (hybridcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridcrx &raquo;</TD></TR><TR><TD CLASS="quote">....but flywheel chunks through my car and maybe in my passengers ***** didn't sound like fun.</TD></TR></TABLE>
ROFLMAO!!!
Mike
Old Nov 14, 2003 | 09:01 PM
Pootie's Avatar
had an act 6 puck w/ my aasco....went through 2 rings and 2 clutch discs in less than 10k miles before i said fudge it and and went w/ a full face....been great ever since......on the other hand, seen act flywheel hold up great to the pucks
Old Nov 14, 2003 | 11:22 PM
hiendgsr's Avatar
Default Re: Fidanza
Fidanza flywheels I believe have replaceable surfaces. So instead of resurfacing the flywheel you can buy a new surface for fairly cheap and not have to replace the entire flywheel. They claim chromoly has heat issues, they develop heat cracks fairly easily.
ACT says that aluminum is not strong enough, 7lb flywheel for normal use and drag racing is not ideal, it's too lite for normal use. They have a Prolite (7 - 8lbs. road racing) and streetlite (12lbs. normal and drag racing). They usually recommend the streetlite. ACT flywheels are also one piece as opposed to Fidanza, which are multiple pieces (steel teeth, surface)
Old Nov 15, 2003 | 02:08 AM
visi0n's Avatar
aasco similar to fidanza?...haha aasco is far superior.
Old Nov 15, 2003 | 05:21 AM
owen_the_soyboy's Avatar
Default Re: (visi0n)
I've been running my ACT prolite chromemoly flywheel all year, daily driven 7000+ miles so far and occasional autoxing.. no problems wirth it yet, I dont expect any either, but its not like I have removed it and had it checked for wear or cracks. Sure cant beat the price for its low weight!
Old Nov 15, 2003 | 07:40 AM
topdog's Avatar
Default Re: (owen_the_soyboy)
if you are running a ceramic face clutch...chromemolly will be your choice..as the clutch will not eat it away like aluminum or stock steel flywheel...if a organic type stock disk is what you have in mind then aluminum will be no problem for you....
also note...chromoly flywheel put dents onto the starter gear....
topy
Old Nov 15, 2003 | 10:21 AM
riceball777's Avatar
Default Re: Flywheels: Aluminum or Chromoly (geezr)
chromoly
get a act prolite
Old Nov 15, 2003 | 03:50 PM
Bbasso's Avatar
I have a comptech Al and no problems in 5 k miles, and ACT clutch too.
Old Nov 15, 2003 | 03:58 PM
hybridcrx's Avatar
Default Re: (topdog)
chromoly flywheel puts dents into the starter gear??????
Wtf does that mean? Please elaborate and give some evidence if you would be so kind.
msbhvn_DC2
May 18, 2006 05:01 PM
Nicram
Oct 18, 2005 06:20 PM
stehigs321
14
May 16, 2004 08:54 PM
Dc_John
Apr 2, 2004 07:57 PM
Joel_MN
Aug 11, 2003 03:31 PM
