can u use a super AFC in place of a fmu
its a turbo h23 accord
inline fuel pump ,440cc injections ,adjustable fuel pressure regulator
going to turn the boost up to about 16psi
so i was going to buy a adjustable rise rate fmu or just get a super AFC
There area lot of things you "can" do but it's not a good solution. The FMU isn't really necessary with an AFC and large injectors, but since the AFC doesn't have a CLUE if you're boosting or not, if you tune it right under boost, you'll be REALLY rich if you're not boosting.
Another fringe benefit of the AFC - at part throttle, since it bungles your MAP signal to the ECU, you can be running 3-4 psi of boost and the ECU will never leave closed loop mode! All the detonation you ever wanted and more!!!
