K-series oil filter on a B-series
Old Nov 14, 2003 | 03:23 PM
1ntensiveVTECivic's Avatar
Default K-series oil filter on a B-series
Has anyone ever done this before? If so will I be running into any kind of problems using this filter. Its feels like it boosted the oil pressure on brothers 00 SI when your cruising on a steady speed its jerks-pulls never ever did that before.
Old Nov 14, 2003 | 03:31 PM
Carlo's Avatar
Why would you get a K series oil filter for a B series anyway?
Old Nov 14, 2003 | 03:32 PM
poison's Avatar
Default Re: K-series oil filter on a B-series (1ntensiveVTECivic)
It results in a little higher oil pressure.
Does it do anything?
No.
Old Nov 14, 2003 | 03:35 PM
egturbo's Avatar
yes ive used it on my b18b and it makes the oil pressure go up.. if ur turbo do not do it. but all motor is ok.. if ur turbo and do this it'll make oil shoot out of the seals and mess up the turbo.. just my .02
So, my brother should stick with the b-series oil filter.
Old Nov 14, 2003 | 03:49 PM
degooser's Avatar
Default Re: (1ntensiveVTECivic)
my local HONDA does not even sell the bigger oil filters anymore...just the tiny small ones..
Old Nov 14, 2003 | 03:51 PM
poison's Avatar
Default Re: (degooser)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by degooser &raquo;</TD></TR><TR><TD CLASS="quote">my local HONDA does not even sell the bigger oil filters anymore...just the tiny small ones..</TD></TR></TABLE>
Yeah, they are tiny as hell. Honda switched to FRAM filters now.
Old Nov 14, 2003 | 03:54 PM
pdiggitydogg's Avatar
which is why i continue to buy the pure1 after seeing the damn new ones...
Old Nov 14, 2003 | 03:56 PM
RICE POLICE SIP's Avatar
Default Re: (pdiggitydogg)
Yeah they went from the old oil filters to just using one...... they are all the same now i believe......
Old Nov 14, 2003 | 04:07 PM
99blackcivicSi's Avatar
Default Re: (92boostn'hatch)
Isnt the S2K oil filter the same size and the same make as the Older filters for civs and tegs? that is what i am going to buy, i was told that they will work
Old Nov 14, 2003 | 07:37 PM
degooser's Avatar
Default Re: (99blackcivicSi)
i asked them if they still have the big ones and they sed that they were discontinued...so im like..uhh ok..
go buy a napa gold filter if you want a bigger one..
Old Nov 14, 2003 | 07:45 PM
ejprimo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99blackcivicSi &raquo;</TD></TR><TR><TD CLASS="quote">Isnt the S2K oil filter the same size and the same make as the Older filters for civs and tegs? that is what i am going to buy, i was told that they will work</TD></TR></TABLE>
worked on my b16a w/o any problems. btw the part # is 15400-PCX-004.
Old Nov 14, 2003 | 07:48 PM
mikefxu's Avatar
Default Re:
my 89 accord with 2.0 liter engine calls for the taller filter when i checked for my 96 civic 1.6 liter it called for the shorter filter but ive been running the taller filter and had no problems even if ur turboed u can use a valve to reduce pressure on the turbo. i figure in the long run it keeps ur oil cleaner longer
Old Nov 14, 2003 | 07:49 PM
DCStreetHtch's Avatar
Default Re: (ejprimo)
i use it because its easier to get my hands around to remove when its time for a new one, simple conveniences! i hear it bumps up oil pressure too...
-Bryan-
Old Nov 14, 2003 | 07:53 PM
Jowee's Avatar
Default Re: (EGStreetHtch)
I like the RSX oil filter in my R. It makes it feel a bit peppier or it could be psychological.
Old Nov 14, 2003 | 08:05 PM
lo0nY's Avatar
local dealership, said that the newer filters are better, boost oil pressure anywhere from 2-8......
Old Nov 14, 2003 | 09:00 PM
Ricey McRicerton's Avatar
Default Re: K-series oil filter on a B-series (lo0nY)
Yep...the S2k filters are still the good ol big ones. I have one on my D series motor and it works just fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">local dealership, said that the newer filters are better, boost oil pressure anywhere from 2-8......</TD></TR></TABLE>
This is not good for turbo guys. And it has been proven that the new oil filters are not as good...
Old Nov 14, 2003 | 09:03 PM
Frozen E's Avatar
H-T White Ops
Use the ones you're supposed to use. I get the Fram ones with the grippy stuff on the end. Easy oil changes.
Old Nov 14, 2003 | 09:24 PM
Default Re: K-series oil filter on a B-series (FrozenSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lo0nY &raquo;</TD></TR><TR><TD CLASS="quote">local dealership, said that the newer filters are better, boost oil pressure anywhere from 2-8......</TD></TR></TABLE>
Better for what?? N/A yeah probably turbo NO more oil pressure means more pressure going to my turbo then that means blowing the seals out and taht means bad turbo.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FrozenSi &raquo;</TD></TR><TR><TD CLASS="quote">Use the ones you're supposed to use. I get the Fram ones with the grippy stuff on the end. Easy oil changes.</TD></TR></TABLE>
FRAM
That is why no one wants to use the new filters because of their inferior build quality
Old Nov 14, 2003 | 09:28 PM
spoon_ek9's Avatar
Default Re: K-series oil filter on a B-series (99blackcivicSi)
if your turbo couldn't handle 75-80psi oil pressure and fail because of that, then you really need to upgrade your turbo to a real one.
Old Nov 14, 2003 | 09:33 PM
SLeePeR012's Avatar
Uhh, Dealerships will say <U> ANYTHING </U> to you.
The new Fram ones suck man.
THey still have some Filtech left atleast in my dealership.
Old Nov 14, 2003 | 09:42 PM
Default Re: K-series oil filter on a B-series (spoon_ek9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoon_ek9 &raquo;</TD></TR><TR><TD CLASS="quote">
if your turbo couldn't handle 75-80psi oil pressure and fail because of that, then you really need to upgrade your turbo to a real one.</TD></TR></TABLE>
It is just the consistant wear on the seals in the turbo with the upped oil pressure that scares me a LOT i do not drive the car ona daily basis but daily driven turbo cars i would be a little weary of uping the oil pressure. Call me crazy but that is the truth
Also everything is a wear and tear part WHY put MORE pressure on the seals when all they will do is BLOW! and i DO have a real turbo on my car
Old Nov 14, 2003 | 09:43 PM
You sir, are an idiot. Why would you want to try and blow out your turbo seals?? I personally like my turbo just fine, and am getting oil leaking past my seals when I first start the car. My turbo is a "real turbo" and have gone back to the S2k filters because they don't cause my turbo seals to leak.
Old Nov 14, 2003 | 09:50 PM
spoon_ek9's Avatar
Default Re: K-series oil filter on a B-series (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">You sir, are an idiot. Why would you want to try and blow out your turbo seals?? I personally like my turbo just fine, and am getting oil leaking past my seals when I first start the car. My turbo is a "real turbo" and have gone back to the S2k filters because they don't cause my turbo seals to leak.</TD></TR></TABLE>
whatever you say man. all the turbo/car i have played with didn't have any problem with oil press over 75psi. as the matter of fact, some cars are over or close to 100psi(stock oil press) and even stock turbo can withstand that. i personally don't know what turbo do you own which have a weak oil seal.
Old Nov 14, 2003 | 09:53 PM
I run the Greddy (mitsubishi) Tdo4h-15g. I see no reason to up the oil pressure and push on the seals constantly.
