b16a lsd
Old Nov 14, 2003 | 01:18 PM
disturbd696's Avatar
Default b16a lsd
how do you tell if your tranny has a lsd. what type of tranny fluid would you use.
Old Nov 14, 2003 | 01:19 PM
slammed_93_hatch's Avatar
Default Re: b16a lsd (disturbd696)
SEARCh and if this is the stock tranny for the b16a you don't have LSD unless its aftermarket
wow look at this 30 seconds later i found it in a search
https://honda-tech.com/zerothread?id=671415
Old Nov 14, 2003 | 01:46 PM
seannabend's Avatar
Default Re: b16a lsd (slammed_93_hatch)
there were plenty of b16a's that had a lsd stock, at least the jdm ones like mine
Old Nov 14, 2003 | 01:50 PM
95DXPhiladeph's Avatar
is there special LSD tranny fluid? like for my JDM b18c?
Old Nov 14, 2003 | 03:00 PM
shermanyang's Avatar
Default Re: (95DXPhiladeph)
i use Honda Automatic Tranny fluid for my Gsr tranny with Quaife. it lubs better and transfers heat a lot better than regular oil. and to tell if it's got an LSD, look in the axle holes and if you can see right through it, then it's got an LSD. if you can't or there is a shaft or something in the center of it, then it's an open differential tranny.
CivicSwapper
Nov 30, 2006 02:16 PM
matt56
Sep 13, 2006 09:09 PM
matt56
Sep 13, 2006 03:58 PM
CivicSiR7
Oct 4, 2001 08:13 AM
