Sway bar question
for a 92-95 civic SI, Suspension Tecniques offers 2 different front sway bars:
a) front sway bar for civic with stock front sway bar (1 inch diamter)
b) front sway bar for civic without stock front sway bar (3/4 diameter)
Why is it that these are different widths? The rear sway bar they offer is 3/4 either way you go about it.
If you have an SI then you want the kit with the 1"bar. They have it listed as 2 kits for all 92-95 civics, ones with a factory front bar, and ones wihout. The kit without the factory front bar is a smaller diamerter because it utilizes a different type of endlink but if you car already has a factory bar then the kit uses your stock endlink mounts. hope that helps.
